Thread: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 112
  1. #41 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Kemmerer, Wyoming
    I am impressed that you had a noticeable decrease in intake temperatures. that cold air intake looks really good.
  2. #42 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTP Level Member buickman104's Avatar
    NYC
    What were the intake temps before and after the cold air intake?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #43 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by buickman104 View Post
    Running 20 miles this morning to work
    65 mph most of the way (2 stop signs half way)
    52 degree outside
    63 degree intake air temperature
    If I run faster intake air temp drops.
    If I run harder the intake air temp drops.
  4. #44 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    77 outside
    92 intake air temperature on the way home.
  5. #45 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Never Never Land
    Not bad at all. My intake temps are typically a minimum of 120* on an 80* day cruising at 65mph.
  6. #46 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    NYC
    Those are some great temps and you don't have to worry about the filter getting caked in mud like the guys that stick the filter right into the fender well.
    Very slick!
  7. #47 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Better pictures of the air cleaner.
  8. #48 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    I'm happy with my open cone but I gotta give you props, thats a very clean and sweet looking/working home made CAI. Nicely done. You could maybe even wrap the aluminum part in some kind of insulation/dynamet to get colder temps and quieter sound.
    04 GTP -HAI, 1.9 rockers.
  9. #49 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by SnowTh1ef View Post
    Agreed!!
    Bought some stainless dual tips. Tried cleaning and polishing the old first but I like the duals better.
  10. #50 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    NYC
    Those are beautiful! Where did you buy them? Are they clamp ons? If so what diameter?
  11. #51 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GT Level Member blownGP's Avatar
    Sep 2013
    Iowa
    Quote Originally Posted by sseilmnop View Post
    Hmmm I think I'm gona have to try somthing like this if I ever get time
    2000 2500 Chevy with 6 inch lift build thread- http://www.gmt400.com/forum/showthre...d-Crew-Cab-454 2006 Grand Prix supercharged build thread- http://www.grandprixforums.net/blown...ead-82585.html
  12. #52 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Kemmerer, Wyoming
    I like the dual tips better. I have similar ones on my special edition but they aren't very shiney
  13. #53 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
  14. #54 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Calipers are 1/2" open. About 22 fins per inch. This is a keeper.
    Going to need a threaded sensor measures .812" ID.
  15. #55 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    NYC
    That looks so nice! Do you expect to have to do any cutting to make it fit?
  16. #56 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    It will fit. My black bonneville has a vw radiator in it. I had to cut tubing/bracket but it was pretty easy.
  17. #57 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Tips mounted. Still not perfect but close.
  18. #58 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Which radiator did you end up getting?
  19. #59 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Your quick, that's were I got it coming from.
    CU98
  20. #60 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Kemmerer, Wyoming
    any idea how many finds per inch the frozen boost type 101 heat exchanger has?
    http://www.frozenboost.com/product_i...a933e9df1332fd
  1. VS Cam vs S2/Phenolic Intercooler
    By Nchristopherson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2013, 08:10 AM
  2. Ported gen5 and phenolic intercooler
    By 2007gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 05:51 PM
  3. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
  4. Phenolic Intercooler Spacer
    Last Post: 03-22-2009, 12:03 PM
