Thread: Supercharger Pulley Swap [*]
Results 1 to 20 of 20
  1. #1 Supercharger Pulley Swap [*]
    GTX Level Member webracin's Avatar
    Arkansas
    This HOW TO write-up on Changing your Supercharger Pulley has been added to the How To section and can be found HERE.
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: Supercharger Pulley Swap
    chicago
    now you need to do another write up on how to change MPS pulley.
  3. #3 Re: Supercharger Pulley Swap
    Oklahoma
    I need to do something like that. As simple as it is, its still good information as that breather nut tend to be the part the kinks up all well laid plans to me.
  4. #4 Re: Supercharger Pulley Swap [*]
    Merriam, KS
    Quote Originally Posted by webracin View Post
    Say, I was just browsing the forums and came across this write up, and thought I'd let you know that one of the picture links is wrong. The second thumbnail on step four links to 'Install_2.JPG' when it should link to 'Setup2.JPG'.
    Thanks for the how-to though!
  5. #5 Re: Supercharger Pulley Swap [*]
    SE Level Member Bigbm80's Avatar
    Feb 2009
    Princeton NJ
    approximately how much HP will swapping the pulley add?
  6. #6 Re: Supercharger Pulley Swap [*]
    You have to have supporting mods...you just can't drop a pulley size and except to have a faster car.
  7. #7 Re: Supercharger Pulley Swap [*]
    Feb 2009
    Princeton NJ
    alright, what else would I need in addition to a the smaller pulley?
  8. #8 Re: Supercharger Pulley Swap [*]
    Apr 2009
    Nassau County, New York
    do you really needed the pulley remover? (yeh i no its a stupid question)
  9. #9 Re: Supercharger Pulley Swap [*]
    Charles City, IA
    Unless you are super man and plan on pulling the old one off with your hands then yes. It also installs the new one.
    SMGPFC Two Nipple General
  10. #10 Re: It's been a good week :)
    GT Level Member rolyat's Avatar
    OKC
    could you take the entire s/c to a machine shop and have this done?
  11. #11 Re: Supercharger Pulley Swap [*]
    Topeka, KS
    Could but'd you probably pay out the ass and why take the S\C off and have to buy new gaskets and worry about it sealing if you don't have to. Just rent one, buy one , or have someone put it on for you.
  12. #12 Re: Supercharger Pulley Swap
    OKC
    Quote Originally Posted by rynoman03 View Post
    Because Im buying a complete unit and have an mps hub to put on, so I thought that would be the easiest way.
  13. #13 Re: Supercharger Pulley Swap [*]
    Topeka, KS
    There's a grand prix chapter for the OKC area i believe. See if you can google them surely someone has a puller that will install that for you for free. I have a puller but i'm way up in Topeka and it's lent out to another member at the moment.
    Tornado Alley Club Grand Prix....
    http://www.okgpc.com/
  14. #14 Re: Supercharger Pulley Swap [*]
    OKC
    Alright, I'll look into it. thanks
  15. #15 Re: Supercharger Pulley Swap [*]
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    does the little cap on the end of the snout unscrew?... ... I tried prying it out and snapped off the edges assuming it was a pop in christmas tree... I think I'm screwed now... ugh...
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  16. #16 Re: Supercharger Pulley Swap [*]
    SE Level Member Konvinced89's Avatar
    Layton, UT
    Quote Originally Posted by 03GTPLE View Post
    I have a similar problem..only i screwed right through the plastic piece and now i cant get the pulley to budge. Now its bent beyond use..
  17. #17 Re: Supercharger Pulley Swap [*]
    Akron Ohio
    can you use any pulley remover, or does it have to be the Gm supercharger pulley remover?
  18. #18 Re: Supercharger Pulley Swap [*]
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Quote Originally Posted by joshsgtp View Post
    DO NOT use any "Pulley Remover" You can damage the snout doing so. Rent one from ZZP or one of the other online vendors. Maybe there is someone local in Ohio that has one available too.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  19. #19 Re: Supercharger Pulley Swap [*]
    Akron Ohio
    Thank you, im new to all of this
  20. #20 Re: Supercharger Pulley Swap [*]
    Banned
    Nov 2011
    racing in nassau county
    Need a pully puller message me. If u can let me. Borrow or. Sell me one thanks
  1. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  2. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
  3. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
