Re: 97-03 Cluster Gauge LED Install
Just bright whites. And my ****s all smoking and not working hahahah.
Taking to my work later to get fixed
TimMcCallum
I did this tonight and when I put the bulb into the socket it started smoking. Idk what to do, that socket no longer works. Also, its not very red with the leds. Its like a pink
Lemme guess...you put a white bulb in there?
Nick C.
Ok leds run cooler and draw less voltage so not sure why it would smoke?
Better change Tims name to Captbreakalot now
Silver2kgtp
Great write up!!
Thanks.
Yes, Great write up. This will be useful since I just acquired white faced gauges for 2002 GP, and also got the carbon fiber gauge bezel for 2001 GP. Plan to install LED's in cluster (in an older GTP that I scrapped, the heat from the OEM 194 bulbs caused problems with the printed circuit on back of gauge cluster, and there was no way to repair).
LED's give off very little heat.
About removing the red film, I am going to attempt to remove the red film on the old gauge cluster to see results.
Going to try different color bulbs also.
Any word from Diode Dynamics when they are releasing more products?
Just shy of 3 months since I installed mine and one of them has gone out.
http://i236.photobucket.com/albums/f...psfuz9yqcz.jpg
Paul J McCain
They won't be in for a few weeks, but I'll post updates when we have them
Very unique design, and they are non-polar, so you don't have to guess and check
(perfect for gauges, which can be annoying to test)
Nick C.
Update on these? I'm interested. I'd like to do LED's.
The Guz
Im impressed.. I have done mine twice with 2 different style bulbs and they have both had like a 40% failure rate. I NEED to find some that wont go out and die on me.
4THGENCAMAROFAN
We have Hp3's in stock for every color except for cool white at the moment
Nick C.
Paul J McCain
Nick C.
Nick how is the 360 degree light dispersal from the sides of the HP3?
The Guz
That's what makes the HP3 special. It does an excellent job dispersing the light evenly
Nick C.
I need to do this, one of my OG lights on the tach went out.
I did mine tonight and it looks AWESOME!! Anybody know the replacement number for the lil lights??
Just ordered the HP3's from DD. We'll see how they do. I'll be sure to upload pics.
If you don't find them bright enough, we also offer the HP5's which are twice as bright as the HP3
Nick C.
Google tells me 194's are about 25 lumens. Hp3's are over double that. Should be plenty bright
4THGENCAMAROFAN
Nice. I ordered a back up set of HP3's for myself when these others go out.
