Thread: How to Install a DIY aux Input Jack in a 97-03 Radio
Results 41 to 60 of 61
  1. #41 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    thats how it works, needs a cd in there, or a tape, depending on where you tapped in.
  2. #42 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Oct 2014
    St Augustine FL
    I have done this mod on 2 radios. One was the original deck that came in my 02 GTP, the the other was a deck I pulled from a 2002 ish S10. Both CD player have developed issues playing CD's, inert disk and a few seconds later the player spits it out and display reads 'ERR'. Has anyone had any luck with fixing the CD players? I may go to the junk yard and get a new disk drive to swap into my head unit.
  3. #43 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    thats cause its a old radio. new drive should fix it up. i got them codes way before i did the aux install. and still do. my cd wont play if its real cold out too. gets a E 20 code on the screen or something like that and spits out the cd. once the inside of the car is heated up it works fine.
    truth is i went through my tape deck not the cd. tape still works like a champ.
  4. #44 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    I have a cassette and cd changer set up, the cd aspect doesnt work, i press play and it says cd for a few seconds then changes back to fm radio. Would this mod work?
  5. #45 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    Where 4T65E's were born
    Probably not through the broken CD module. It has to be able to play a CD to continue accepting audio from it. It would work on the cassette player.
    Sold.
  6. #46 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Nov 2011
    Damn, so there's no way to do this, i might consider replacing the unit after all
  7. #47 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    you can use the tape deck. its how i did mine.
  8. #48 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    The GP I have with the cassette deck radio (with the EQ) is parked for the winter.
    I am going to try adding this input jack.
  9. #49 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Oct 2013
    United States
    Were either the ribbons and wires used on specific years, rather than splicing into the ribbon would an earlier HU from a junk yard be usable. Could a hack be used to install a later model with a built in Aux input be used to get around the vin theft system.
  10. #50 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    I don't know if they were used in specific years or certain model radios. Do you know what yours is yet? Check before trying to get another radio. Even still its completely doable but requires some skill with soldering, as well as a good soldering setup. Theftloc could be bypassed with a code calling a certain number, idk if it works anymore.
    Sold.
  11. #51 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Jul 2010
    Philly
    Think i'm gonna give this try on my single disc cd player. If I understand right I should use the 4th and 5th pin to tape into the radio part so I wouldn't need a CD in the player. Then use the 2nd pin for ground. Do I have this right? I assume the 4th pin is for left and the 5th pin is right, not sure if thats right
  12. #52 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Donating Users seventone's Avatar
    Mar 2013
    midwest
    Got my input plug from an old computer tower.
    1997 Black GTP Coupe | 1997 Black GTP Coupe | 2001 Silver GTP Coupe | 2001 Red GTP Coupe
  13. #53 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Feb 2009
    Virginia
    really like this one. I think bluetooth would be an awesome add-on too.
    https://www.google.com/search?q=add+...w=1920&bih=955
    11 is louder than 10!
  14. #54 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Does anybody know when the ribbon cable was replaced with the connector style? And there doesn't need to be a wire grounded to the frame? Just solder the grounds on each side, connect them into 1 wire, and then solder that wire to the jack, that's it?
  15. #55 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    StayFree - clear out your mailbox
  16. #56 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Apr 2015
    Quote Originally Posted by kewGTP View Post
    Hopefully that worked, I deleted my inbox and outbox.
  17. #57 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Quote Originally Posted by trey9778 View Post
    but broke the soldering points on the circuit board.
    I was getting ready to fix my lights and while searching the forum ran across this thread. As I am looking to see if it address two questions I have, I saw this post and even though it is old, I thought incase someone else runs into this issue, I might make a suggestion.
    I wish I had a picture to look at, but usually the heat will lift a pad. It basically breaks down the glue that was holding the traces. Depending on how far back, sometimes you can fix it by carefully scraping some of the "green" off the attached etch exposing some copper. Then if you can bend the lead without shorting anything, or attach a jumper wire over to the lead.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  18. #58 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    SE Level Member GrandPrixGT1's Avatar
    Jan 2017
    Mount Airy, MD
    Dont mean to bump a super old thread but I am planning on doing this mod. Do you still have the pictures? Photobucket has eaten them.
  19. #59 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Dec 2012
    I do have them on my hard drive at home. I'll try to get them uploaded somewhere else
    Sent from my SM-G930T using Tapatalk
    Sold.
  20. #60 Re: How to Install a DIY aux Input Jack in a 97-03 Radio
    Jan 2017
    Mount Airy, MD
    Ok cool thank you.
  1. How to add a line input jack on 04+ with XM
    By OH4CompG in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2013, 10:55 PM
  2. Is there a factory radio that will bolt in with an Aux jack?
    By My427stang in forum Audio, Security & Visual Electronics
    Last Post: 11-26-2012, 06:39 AM
  3. 2001 stock radio adding mp3 jack
    By 2001goldGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 03:17 PM
  4. '08 With Factory XM Auxillary Jack Install
    By RealMcCoy in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 05:40 PM
  5. Radio Aux input Jack Install (How To)
    By JJ91284 in forum Audio, Security & Visual Electronics
    Last Post: 08-25-2010, 11:19 AM
