well thanks for the replies but i got it in. i did not see that there are 2 holes to mount the unit, and one of the visiable holes are not to mount, but to eliminate. you need to cut along the windshield. its very scary and you need to be patient and relaxed to do this. i recromend taking a break from the main cut to the final cut. just so you do not get ahead of yourself and nick the glass. once you cut out the hole to the right you will see a new hole. cut from the left hole that is visable before you start, the the hidden hole to the right. if the 2 metal clips dont line up that are right behind the speedo, then its not right.
key trick. make sure your unit is fully functioning before you cut.
question. why does my high beam light on the h.u.d. flicker when the turn signals are off? when i hit the turn signals it stops. i dont ever use the high beams due to my single beam h.i.d.s (hey the price was right )
any imput?
