Thread: Adding HUD and a DIC to your 97-03 GP
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 41 to 60 of 167
  1. #41 Re: Adding HUD and a DIC to your 97-03 GP
    East Northport ny
    im trying to do this mod to my 99 gp but i dont know where to find the harness, can anybody tell me where i should look for it? its a 99 so it should be there right?
  2. #42 Re: Adding HUD and a DIC to your 97-03 GP
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    99s don't have the harnesses. only 97s and 98s have them because GTP was a factory option on GTs for those years, rather than being a model of its own.
  3. #43 Re: Adding HUD and a DIC to your 97-03 GP
    East Northport ny
    so im gonna have to do all the splicing?
  4. #44 Re: Adding HUD and a DIC to your 97-03 GP
    Michigan
    i do believe. if you whip out your DIC and look down to the side near the glove the harness would be there. the HUD switch harness would be inside the dash. take the instrument cluster out and it'd be down to the right about where the switch would go.
  5. #45 Re: Adding HUD and a DIC to your 97-03 GP
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    Ive got a question I am trying to install a hud on my 99 gt and the plugs I have to got to the hud switch is a 6 pin plug that has only five wires in it and the wiring chart shows that there are seven wires to the switch and the switch has seven pins? do i need a new plug?
  6. #46 Re: Adding HUD and a DIC to your 97-03 GP
    SE Level Member snoplow's Avatar
    OhiO
    isnt the windshield glass between the hud cars and non hud cars different?
    eventually ill take a pic of the gtp too
  7. #47 Re: Adding HUD and a DIC to your 97-03 GP
    no it is the same
  8. #48 Re: Adding HUD and a DIC to your 97-03 GP
    OhiO
    every company and gm says theres a difference in the glass between a hud car and a non hud car though. can u see the hud on the glass?
  9. #49 Re: Adding HUD and a DIC to your 97-03 GP
    yes i can see the hud fine
  10. #50 Re: Adding HUD and a DIC to your 97-03 GP
    Quote Originally Posted by snoplow View Post
    Technically the glass is different because there is a little reflective section within in the windshield so you can see the HUD better. I know this from looking at a windshield with HUD and Non HUD. You can still see the HUD on the normal windshield though.
    Snorlax strikes again.
  11. #51 Re: Adding HUD and a DIC to your 97-03 GP
    OhiO
    cool thanks u guys just aved me $$ when i get the new glas thrown in!
  12. #52 Re: Adding HUD and a DIC to your 97-03 GP
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    Ok. So I have a 1997 GP GT and it has a 2000 engine in it. Would I still have to buy the '97 DIC or can i go with the '98-'03?
    -ljmonnin12
  13. #53 Re: Adding HUD and a DIC to your 97-03 GP
    depends wether you are still running the 97 pcm or if you are running the 2000. If you are still running the 97 pcm I have a digital dic. If you are runningthe 2000 pcm you will have to find the 98 02 dic that does not have tire pressure on it.
  14. #54 Re: Adding HUD and a DIC to your 97-03 GP
    Nov 2010
    Sidney, OH
    I posted something earlier but I don't think it showed up. And if it does and i don't see it i apologize.
    I have a '97 GP GT with a '00 engine. Will this effect what DIC I need? Do I still need to buy the '97 DIC or can i get the '98-'03 DIC's?
    -ljmonnin12
  15. #55 Re: Adding HUD and a DIC to your 97-03 GP
    i just explained above
  16. #56 Re: Adding HUD and a DIC to your 97-03 GP
    Apr 2009
    texas
    I have a '99gp se does it have the same harness as a gt or do I need the pigtails and splicing in the mix dic only
    Current 3100 cai & 56mm tb
    Near future 3500(lx9)swap,w/mms stage1 cam, ls6 valve springs,21lb injectors, 56mm tb, pacesettersheaders, 2.5" exhaust cat-less, custom tune
  17. #57 Re: Adding HUD and a DIC to your 97-03 GP
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Have looked but cant find anything. Can a 2000 GTP HUD be installed into 04+ GP??? What are the differences???
    Lambokit to be built!!!!!
  18. #58 Re: Adding HUD and a DIC to your 97-03 GP
    nope the pcm and dic wont communicate kind of like the 97 and any of the other years.
  19. #59 Re: Adding HUD and a DIC to your 97-03 GP
    Unfortunately the HUD from a 2000 will not work in an 04 or above. Most of it is wiring related and the dash itself wouldn't allow the fitment for the 2000 HUD as far as i know.
    I'll refer you to the beginning of this thread http://www.grandprixforums.net/addin...3-gp-8171.html as this is what I used to wire mine into my 97
  20. #60 Re: Adding HUD and a DIC to your 97-03 GP
    Enfield, CT
    hey, i gotta 97 GP SE. i want to convert my dic to digital but do i get the GT DIC or the GTP DIC?
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Thinking about adding a turbo
    By MS1227 in forum Turbo
    Last Post: 12-13-2008, 04:22 PM
  3. adding gauges
    By keenan00gtp in forum Visual/Body Modifications
    Last Post: 10-12-2008, 11:48 PM
  4. news question about adding performance shift
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-16-2008, 11:56 PM
  5. Adding acetone to gasoline
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2008, 01:24 PM
