It was just a sticker that I got for it. They were 2 for $7.99 I think. Put one on my car and one on my dads Monte Carlo SS
There are 4 adhesion pads on the back of the mirror glass. I believed that I used a heat gun and then put my finger nails in between the mirror glass and the plastic surround and then pushed through the holes on the back with my thumbs. If you take your time and are careful enough with it they should just pop off.
I would suggest doing the single row of leds. I thought about the sequential 3 rows of leds but I believe you would need a constant power source for those. The ones right against the back of the glass like you are looking at should be great. You should be able to glue the leds to the black mirror backing and then drill a hole to run the wire out. Then you should be able to just re glue (or some other method if you prefer) the mirror glass over top.
