This information is for 2004-2008 grand prix moon roof repair. May be helpful for other years but mainly those years.
EDIT: IF YOU ARE VIEWING THESE ON THE MOBILE VERSION THE FORMATTING OF THESE POSTS WILL NOT LOAD PROPERLY
ALSO I WILL TRY TO ADD MORE INFO AS I GET FURTHER INTO MINE
ok guys i pulled alot of info from the gm manuals on sunroof repairs and procedures for installation and all. In a few minutes when i finish preparing all the pics to upload i will be uploading them. So just Stand by. Tomorrow i will be taking pics of my own as i take my moon roof apart so i will add them as well.
Document ID: 905315
Power Sunroof Disassembled View
(1) Sunroof Window Bolt/Screw (2) Sunroof Window Panel (3) Sunroof Module Assembly Bracket Bolt (4) Sunroof Window Guide Bumper (5) Sunroof Sunshade Stop (6) Sunroof Sunshade Stop Screw (7) Sunroof Module Assembly Bracket (8) Sunroof Module Assembly Bracket Nut (9) Sunroof Module Assembly (10) Sunroof Module Assembly Bolt (11) Sunroof Sunshade (12) Sunroof Opening Bezel/Lace (13) Sunroof Switch Bezel (14) Sunroof Switch (15) Sunroof Wiring Harness (16) Sunroof Actuator/Motor Bolt/Screw (17) Sunroof Control Module (18) Sunroof Actuator/Motor (19) Sunroof Opening Position Switch (20) Sunroof Opening Position Switch Screw
Sunroof Drain Inspection and Cleaning
Document ID 1004229
Drain Hose Routing
A drain trough encircles the sunroof window panel and water is drained off by the drain hoses located at each corner of the housing. A drain channel spans across the sunroof module at the rear of the window panel and directs water into the trough.
- Check to ensure the front drain hoses are routed down the windshield pillars and out the center of the pillar between the door hinges. Make sure the hoses are not kinked.
- Check to ensure the rear drain hoses are routed through the rear pillars and out of the rocker panel. Make sure the rear hoses are properly routed in the metal roof slot and taped in place.
Plugged Drain Hose
If a waterleak has occurred check for a plugged drain hose at each corner of drainage system.
- Open the sunroof window.
- To test for blockage, pour a small container of water into the module housing drain trough. Check each corner to confirm the drain hose is draining water. Caution: Wear safety glasses in order to avoid eye damage.
- Use compressed air, 241 kpi (35 psi) or less to blow out any drain hose that is plugged.
- Test the system again.
- If the hose remains plugged, check to see it is properly routed and does not have a kink. Refer to Drain Hose Routing.
- Remove the blockage using the following steps.
6.1. Push mechanics wire through the hose to remove the obstruction.
6.2. Use compressed air in order to blow out any remaining material.
Disconnected Drain Hose
Inspect the drainage system for disconnected drain hoses. Complete the following steps in order to obtain partial access to drain hoses and check for a disconnected hose.
- Open the sunroof window panel.
- Lower the headliner as needed. Refer to Headlining Trim Panel Replacement in Interior Trim.
- Connect any disconnected hoses.
- Ensure that the rear drain hoses are properly routed in the metal roof slot and taped in place.
