Re: How to....Sun Roof repair in general
gpse2000
From slamming my sunshade back to hard I broke something up in there and it literally takes two arms to yank it closed and open. It actually doesn't even shut all the way now but opens an extra two inches. What would that be?
On the back of the sunshade there is two notches that are supposed to keep that thing on the track it uses to open and close. My guess is you knocked one of them off the track and that's why its so hard to open and close. To fix that you'd have to take the headliner down
BillBoost37
Please put the years it applies to in the title.
Done
marines542
Could be the rails are damaged or the motor its self. Having it all apart like this I can see how it works. Have some one open it while u listen and look to where its getting hung up and all
Alright. I know for sure that the right side will get hung up for sure as the right will stop and the left will continue a little more. Also when I take the sunroof glass off the arms slide back easily and do not get stuck or pop or anything. Makes me think it may just need greasing do to the weight of the glass pushing down.
burgundybullet
Ummm.....the repair manual has troubleshooting steps for things like that. I'll post em up later for u and we can go from there
Re: How to....Sun Roof repair in general 04-08
burgundybullet
Alright thanks.
Hey it could be the track the motor uses to push the window open.
http://i1272.photobucket.com/albums/...psc62a9024.jpg
In this one I took...if u look on the left side at the copper looking tube there's a plastic rod that the motor pushes to open the window. That could possibly part of the problem ur having
ok I should know this but does anyone have a issue with the motor working perfectly but when you close it all the way it opens back up? Thinking sensor or my damn subs threw it off again.
not forsure on that one buddy
Any chance you could post how to synchronize the sunroof?
Hey dirt dog how did you pull the headliner out? I got it all down but am not sure how to remove it from the vehicle lmao
Let both seats forward, remove headrest and take it out the back door
REDCRAPGP
Comes out passenger rear door easist, if 4dr. Used this method 2 weekends go.
That is what I figured but I couldn't get my door fully opened in garage so I bent it out the trunk. How do I get this damn sunshade out??? I have the glass out and everything but don't see these retainer clips you're supposed to press inward
I took the glass out but I can't figure out what they are referring to as "retainers" anything I pushed didn't budge at all. Not sure if in 2008 they made the GXP sunroof different similar to how they made they changed the wheels from alcoas
Use a flathead
Does anyone have any information for a 2000? Mines been stuck popped up, not back thank God, all winter. If I can't get it to shut I'm going to take it to a mechanic. If this will work that'd be great, I just haven't looked at since this is the only weekend it's going to be nice out!
