Thread: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 177
  1. #101 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Where 4T65E's were born
    I could agree with that. I wouldn't mind having 1-2 beefed up as much as the 2-3 is. I'd recommend it a bit firmer if you like firm shifts. I do and I would like it a little firmer.
    And I can agree, higher mileage 4t65e's often shift like crap. Our impala recently developed slow shifts (116k), it needs help for sure. Its probably how the GP with 171k shifts. The up shifts used to be like you had a shift kit before it got worn out.
    Don't even get me started on how it downshifts stock at about 3/4 throttle, so sad... I was gonna pass someone in the impala and I was waiting...and waiting, come on! lol. Almost a safety issue in my book. The shift kit will take care of it, just have to find time to put it in.
    Sold.
  2. #102 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Feb 2013
    Missouri
    My transmission is a little biased because I've got more done to it to help the shifting, so I couldn't really tell you what a "stock" transmission would shift like. I've got some holes drilled out a bit in the separator plate, the Sonnax Performance Line pressure boost valve, and tighter clutch stacks. Nothing really major, but it all adds up. I can say that when I originally threw together this transmission is still had the DIY shift kit in it (1\2" spacers on top, 3\4" on bottom, and a 2-3 accumulator spring in the 1-2), and after I installed the Transgo kit there was a HUGE difference.
  3. #103 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    SE Level Member jimzssei's Avatar
    Sep 2014
    Great thread!
    4t65e vs 4t65e HD
    Is this the same kit?
    Sent from Browns country
  4. #104 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Oct 2011
    Toledo, OH
    Quote Originally Posted by jimzssei View Post
    Great thread!
    4t65e vs 4t65e HD
    YEP! (I asked the same question.)
    7"
  5. #105 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Sep 2014
    Thanks for the input Fish!
  6. #106 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Nov 2014
    CT
    Hi guys, I am going to be doing this shift kit soon. I notice TransGo sells 1-2 & 2-3 accumulator pistons together. On their website they say they are more durable than the stock ones that "wear out prematurely". Do these need to be replaced? I didn't see any mention of you using new 1-2 and 2-3 pistons so I'm not sure if it's necessary. My tranny has 48k miles on it and no malfunctioning going on besides that I want to firm up my shifts.
  7. #107 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    No you shouldn't have to replace them, I don't often see them get scored or anything. Especially at that mileage.
    Sold.
  8. #108 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Nov 2014
    benton harbor, mi.
    Thanks for the great write up! I wasn't sure if I wanted to try this to my 2000 Buick Lesabre with 188,000 miles. It was slamming pretty hard when going from park to reverse or drive and also shifting very mushy. Repair shop wants $2500 to rebuild, so I installed today and man it shifts great. I might do this to my 2005 Monte Carlo because I'm so impressed with the results. The only tricky part was getting the lines all the way inserted, but not a problem at all. Now I have to do the upper and lower intake manifolds and I'm not looking forward to that!
    I dont own a Pontiac, but I registered just to say a sincere Thank You to 02 Navy Blue for taking the time to make this write up. Good Karma for you, Brother.
  9. #109 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Thanks for the comment, I'm glad it helped you out. Also it doesn't matter if you own a Pontiac or not, were all just w-body/3800 guys here. Lots of info on here for any more things you may need to know.
    Sold.
  10. #110 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    I live here. DirtDog's Avatar
    Jun 2012
    We are not all 3800 guys here. I can assure u of that
  11. #111 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Yup soon I will have an LQ4.
    Sent from my Galaxy Far Far Away
  12. #112 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    02NavyBlue,
    Thank you very much for this write-up! I successfully installed the TransGo shift kit by following your instructions. I also performed the fluid exchange in the manner you specified. It's a completely different transmission than it was a few hours ago.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  13. #113 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Feb 2014
    Grand Forks, North Dakota
    @02NavyBlue or anyone
    Do you highly encourage to get the differential lube line retainer? I got my shift kit today and tranny filter last week and am anxious to install it. From rockauto its like $10 to ship a tiny little piece of metal to where I live and would have to wait about another week.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  14. #114 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Have you checked ebay/amazon for cheaper prices on it?
    2012 F150 STX
    - Gonna be a race truck
  15. #115 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Feb 2014
    ebay has only one that is selling for $18. Amazon does not have any. The rest of the websites that are the selling them want $10 or more for shipping.
  16. #116 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Dayton, OH
    Ohh i see
    2012 F150 STX
  17. #117 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Feb 2014
    The part itself is nice and cheap but you get hosed on shipping for how small it is.
  18. #118 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Yeah they get you with shipping. I paid 6 something to ship all 3 to my house. It would have been cheaper for 1, but really they're so small, a few additional shouldn't even up charge.
    I'd only recommend it, but it's up to you. As long as you understand why we use it.
    Sold.
  19. #119 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Mar 2015
    USA
    Just wanted to say thanks. I just put the kit in my trans along with the diff tube clamp. Went a lot easier than I expected.
    I mostly did this because I was getting that "slip then catch bang" when pulling away from a stop light. Not sure if the kit will really do anything for that issue, but so far so good. (fingers crossed)
  20. #120 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Buffalo
    I have the retainer for the diff line and there is also a clamp on 2 of the 3 other lines.
    I just did the Intense kit over the weekend.
  1. Transgo Shift Kit-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 01:18 PM
  2. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  3. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  4. 4t60e or 4t65e
    By gpboi19 in forum Introductions/Noob Questions
    Last Post: 02-02-2010, 05:21 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
