Thread: Spectre Air Filter Install (Low Budget)
Results 1 to 15 of 15
  1. #1 Spectre Air Filter Install (Low Budget)
    SE Level Member jmdc692's Avatar
    Feb 2013
    Tracy/Sacramento , CA
    2000 Pontiac Grand Prix GTP
    First off, I’m a student on a low budget. There for I must work with what I’ve got. Here are a few pictures and details about my little project today.
    My buddy had just bought a car and it had this cool looking CAI (Cold Air Intake) in it from out of state and it wouldn’t pass smog (in California) due to aftermarket parts (visual). So he had it replaced with a stock air filter box. He doesn’t know anything about cars whatsoever. So I offered to buy the cone filter off of him. He declined and gave it to me instead. The next day I strolled into Autozone with my cone Spectre filter in hand. I saw that Spectre made kits for this and so I bought a Pre made kit for around $40. I took it home and opened it up and started to put it all together but the tubing was too small. I believe the stock intake is about 3” circumference, and Spectre’s kit was like 2”. So I took the kit back and started brain storming. I noticed that the kit was just plastic tubing painted chrome. So I went to Ace Hardware and purchased 2’ of black PVC pipe which was also 3”. This cost me $4. I shoved the PVC into the factory rubber intake hose past the ridges but right before the sensor. I then had to cut off a foot and just eye ball it and made necessary cuts so that it fit. I secured the factory hose onto the PVC using medal hose clamps. From there on the other end of the PVC pipe I inserted my Spectre air filter by removing the little inserts that the Spectre air filter has for different sizes. So now the Spectre air filter fits perfectly over the PVC. Secured this with another medal hose clamp, and it’s not bad for a low budget intake.
    2’ of 3” PVC = $4
    Spectre cone air filter = FREE
    Medal hose clamps = FREE (friends unwanted parts)
  2. #2 Re: Spectre Air Filter Install (Low Budget)
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Looks good.. Basically a free setup. You should clean up the engine bay
    Sent from my SGH-T679 using Tapatalk 2
  3. #3 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
    Ya i just went to the store and picked up a bunch of car cleaner supplies and soap and all that good stuff..
    2000 Pontiac Grand Prix GTP "IF YA AINT FIRST YER LAST"
  4. #4 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
    CLEANED UP THE ENGINE BAY A BIT..
  5. #5 Re: Spectre Air Filter Install (Low Budget)
    I live here. TLSheff's Avatar
    That's how mine has looked for a while, I did the same thing, but had to pay for my Spectre filter.
    Soon going to upgrade to 4" piping for better air flow when I drop pulley size.
  6. #6 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
    why not just go 4" piping now. shouldn't it help with or without the smaller pulley. I live in California so idk how much I can mod my car due to all the smog B.S.
  7. #7 Re: Spectre Air Filter Install (Low Budget)
    SE Level Member 98RedGTP's Avatar
    Feb 2013
    Hazelwood, MO
    Can we get the pictures fixed? Doing this same install thursday.
  8. #8 Re: Spectre Air Filter Install (Low Budget)
    Dec 2012
    Where 4T65E's were born
    It looks good. I like seeing the filter farther from the engine, and closer to either the fender, or the headlight assembly(Where the stock box originally picked up from). It's the difference between a HAI and a CAI.
    I'd also like to see what the first 6 pics were.
    Sold.
  9. #9 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
    hmm I wonder why they aren't showing anymore.
  10. #10 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
  11. #11 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
    but I did decide to ditch the whole set up and plug the filter straight into the throttle body.
  12. #12 Re: Spectre Air Filter Install (Low Budget)
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by jmdc692 View Post
    This was what I've been thinking of doing all along. No need to buy a $300.00 filter kit, just a simple piece of tubing, and a filter. Only thing I might do different, is try to design a baffle between the engine compartment and the filter. Good thing summer is coming. Now I've got something to keep me busy.
  13. #13 Re: Spectre Air Filter Install (Low Budget)
    Feb 2013
    yea I was thinking about that. like a shield like the wiz air and the k&n rite?
  14. #14 Re: Spectre Air Filter Install (Low Budget)
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    Really nice I think I'm gonna do this but not for a few months I actually just put in a K&N air filter in so might as well get some usage out of it lol but it will be nice to have that free space! Maybe I will get a PCM tray or make something for it..
  15. #15 Re: Spectre Air Filter Install (Low Budget)
    GT Level Member GPTAFan's Avatar
    Sep 2012
    Maryville, Illinois
    In case it isn't mentioned. If you're using pvc, get pvc cement. It'll never come off.. unless u want it to :P
  1. UPDATE Finally installed Spectre filter
    By SF9777 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2013, 08:12 PM
  2. Spectre cone filter install help
    Last Post: 01-13-2012, 10:43 PM
  3. 6.75" spectre filter
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-27-2011, 07:00 PM
  4. Spectre air filter or no?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 06-28-2011, 05:58 PM
