Re: How to- Retrofit Projectors 97-03 GP
Thank you sir! Now I just need to figure out how to make the brackets more stirdy so they stop wobbling around everywhere.
Sent from my LG-H901 using Tapatalk
Hey guys with the projectors amazingly sharp cutoff I'm having a pretty big problem with my headlight housing bouncing around on the crap aftermarket bracket. Idk if a stock headlight bracket would move around less then the eagle eye bracket or if I should just try my best to shim it. Any ideas would be helpful thank you!
Might be a stupid question, but do you have the tab inserted properly? There's the obvious one towards the center of the car, but on the other end there's one more smaller one. Kinda have to fandangle it to align it
Sent from my SM-G930T using Tapatalk
Yes I do have both tabs inserted. Its crazy how much they shake. I went and stuffed a bunch of cardboard box around it till I can figure out a more permanent fix
My brackets are aftermarket but don't shake too horribly. I do notice it though. If you move it by hand, it is just the bracket bending right? Nothing actually sloppy
Shim it. I've used stock and aftermarket brackets, and they both move.
Can you elaborate on the Shims?
buickman104
Put something under the light, between it and the bumper to help get rid of the bouncing. I used a few pieces of weatherstripping that I had laying around.
Ya I used carboard box and it worked great but if you get down level with it it looks like complete piss with a 3/4 inch gap between the headlight and bumper lol
i used my stock bracket. i have no vibration or anything and i have perfect view
Anyone have a picture of their shrouds cut? I need a better pic other then the one on club gp. Having a hard time getting the thread all the way back. Thanks
