Thread: More belt wrap with a SSM90
Results 1 to 3 of 3
Frosty More belt wrap with a SSM90 01-23-2013, 09:57 PM
88formula Re: More belt wrap with a... 01-26-2013, 01:48 PM
Frosty Re: More belt wrap with a... 01-26-2013, 04:48 PM
  1. #1 More belt wrap with a SSM90
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Not sure if anyone else has done this but I did it by accident (Wasent reading instructions when installing) and it ended up working exceedingly well. I was able to run a 3.4 ssm90 pully with no belt slip whatsoever.
    The standoff and pully are supposed to replace the coil pack bracket stud on the left. Instead i threaded it into the extra threaded hole in the head / bracket.
    Below is zzps method.
    Some people were pming me about seeing it actually working so heres a video.
    Edit: Video of it working with a 3.4 pully.
    Also the belt im using with a 3.4 pully is a K060956 which is slightly longer then the belt zzp recomends normally with their idler setup.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: More belt wrap with a SSM90
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    If this works well without issues I am really surprised no one else has tried this... I am even more surprised that I am the first person to comment on this.
  3. #3 Re: More belt wrap with a SSM90
    Apr 2011
    South Dakota
    I can post video and scans of it working. You can even see in the picture the pully is spinning because the engine was running when i took it. Got over 4k miles on it so far... Normally when you have belt slip you'll see boost numbers slowly dip off from peak psi as rpm goes up. Mine just keeps on climbing even with a 3.4 pully and e85. Hit 14.5 psi the other day.
    I love Decker<3
  1. ssm90 with zzp ssic belt size
    By 02bluegtss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2012, 08:17 PM
  2. PC Belt Wrap Kit finally on the car....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 10-20-2008, 10:11 PM
  3. SS M-90 belt wrap solution!!
    By chico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:38 PM
