Thread: Adding Performance Shift [*]
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
  1. #1 Adding Performance Shift [*]
    St. Louis Mo.
    This HOW TO write-up on Adding Performance Shift has been added to the How To Section and can be found HERE
    I posted this on the KC and STL Boards, but I figured I would post it here as well.
    Its just the installation portion of the PS wiring to the PCM. Everyone varies on how they setup their switch for the PS option. Whether it be the Shifter Button or a flip switch located somewhere else. This is the part is the trickiest for most people.
    I hope you all find it useful
    James Shafer
    St. Louis MO
    GT Level Member DuBob's Avatar
    Lititz, PA
    GREAT write-up James. I moved this to the How-to section.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
    St. Louis Mo.
    LOL I was wondering what happened.
    Sorry I did not see this section in the first place.
    Thanks for the change sir!
    James Shafer
    St. Louis MO
    Port Hope Ont,Canada
    Very nice write up
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  5. #5 Re: Adding Performance Shift [*]
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    i have a 2k gtp and i have this option, but has anyone ever noticed the performance shift on the gauge cluster? how can i getthis to light up?
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  6. #6 Re: Adding Performance Shift [*]
    I have a 2000 GTP and my "Performance Shift" light comes up when I press the button.
  7. #7 Re: Adding Performance Shift [*]
    GTX Level Member webracin's Avatar
    Arkansas
    Not 100% sure on this, but I believe that if you have the DIC that has "performance shift" then that is the one that will light up. If you dont have it on the DIC, then the cluster one will light, but you cant have both.
    It was about 4 years ago that I read something on that, so I may be wrong, and never checked into it because the DIC lights up fine for me.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  8. #8 Re: Adding Performance Shift [*]
    Moore, Oklahoma
    1998 is the only year Perf Shift will light up in the Cluster as far as I know, otherwise it will light up in the DIC. You can add the Perf Shift in the cluster too as long as you have the right socket + blub.
    I added it to mine so when Perf shift is on my DIC lights up and so does the cluster. I added it because I had a spare blub and socket laying around. Figured what the hell, right? :-)
    NOTE: I don't know if this will work on 2001+ that don't have Perf. Shift factory wired up.
    Shawn W. Larsen
  9. #9 Re: Adding Performance Shift [*]
    Apr 2008
    Decatur, IL
    so what would i need to do to get that to light up? would the socket and bulb be something i could find locally or would i have to find on to take off another gp? i think it would be cool to have both light up also.
  10. #10 Re: Adding Performance Shift [*]
    Moore, Oklahoma
    I had a spare cluster so I took the blub and socket out of there. I donno where you can get one honestly. Dealer may sell replacements for your cluster. Either that or go to a junk yard and yank the blub/socket. Several of the idiot lights are the same blub/socket including the oil pressure. Take out your cluster, you'll see exactly what i'm talking about. The socket is opened on the Perf Shift light. Just put a blub/socket in that hole and thats it. It lights up blue, just like your brights light
    Shawn W. Larsen
  11. #11 Re: Adding Performance Shift [*]
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Anyone know if a 2002 gt pcm would be set up for this already? Or would it have to be programed? Thanks!
  12. #12 Re: Adding Performance Shift [*]
    SE Level Member littleboybluebvc's Avatar
    May 2008
    Idaho
    I've read a few of your posts and was wondering if you did anything to get your DIC to light the perf. shift indicator.
    i've got a '98 GTP and can see a vague outline for it on the DIC, but it doesn't ever light, even when turning the key and cycling power. do i need to run a wire to the PCM like in the mod, or is it something else?
    Any help would be appreciated...Thanks.
    White '98 GTP Sedan with K&N Kit...Not much Else, But still Whining like a baby'!!!
    Brian Christensen
    Boise, ID
  13. #13 Re: Adding Performance Shift [*]
    May 2008
    staten island,NY
    Quote Originally Posted by WhiteGT View Post
    when i had my DHP i did this to my 02 GT and i got performance shift to light up on my DIC, now that i switched to an intense PCM it doesnt light up anymore
  14. #14 Re: Adding Performance Shift [*]
    May 2008
    Ontario
    Quote Originally Posted by QwikGT View Post
    I mean if the stock pcm will work with the perf shift or will I have to get the pcm out of whatever car I get the shifter and wiring from? Thanks.
  15. #15 Re: Adding Performance Shift [*]
    May 2008
    staten island,NY
    a stock pcm wont work unless the "performance shift" is enabled in the pcm. meaning you either have to get an aftermarket pcm or flash the tables into the stock one
  16. #16 Re: Adding Performance Shift [*]
    May 2008
    Ontario
    But as long as I take the pcm out of the car I get the shifter and wiring from will I be fine or could it cause other issues?
  17. #17 Re: Adding Performance Shift [*]
    Jul 2008
    brunswick,ga
    i have that perf light on my se do you think it will work on mine an also do u have to have a programmer to check the shift switches an all that other stuff
  18. #18 Re: Adding Performance Shift [*]
    St. Louis Mo.
    Quote Originally Posted by littleboybluebvc View Post
    It will not light up until you have your performance switch installed and the PCM is setup to have it run. It was in my 98 GT's DIC and it never light up when I started my engine. It only will light once its engaged.
    James Shafer
    St. Louis MO
  19. #19 Re: Adding Performance Shift [*]
    St. Louis Mo.
    It means the performance switch feature in your Intense PCM was not setup to run. You can switch it on, but more than likely Intense tweaked your daily driving transmition settings. So you would either copy those settings to your performance shift and change your daily driving, NONPerformance Shifting mode, that is how I have mine setup.
    James Shafer
    St. Louis MO
  20. #20 Re: Adding Performance Shift [*]
    St. Louis Mo.
    First off you do NOT need the performance switch leather knob to enable your performance shift. If you read my write, I said in there you do not need the shift knob to activate it. You need simply a flip switch to activate and deactivate the PS mode. You just need to have the wiring setup for the PCM to switch it on and off. And you can have a grounded flip switch on the dash or center console if you want to do the same thing as the leather shift knob would do.
    Its really just a preference to keep my car looking as close to stock as possible inside.
    James Shafer
    St. Louis MO
  1. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  2. Bad Wreck Photos
    By GTPluv in forum Off Topic Discussion
    Last Post: 12-17-2007, 12:12 PM
