Thread: Toluene + Gas Mix
Results 1 to 16 of 16
dert Toluene + Gas Mix 01-30-2013, 02:27 PM
Bio248 Re: Toluene + Gas Mix 01-30-2013, 05:09 PM
Nighthwk12 Re: Toluene + Gas Mix 01-30-2013, 06:38 PM
dert Re: Toluene + Gas Mix 01-30-2013, 10:56 PM
Bio248 Re: Toluene + Gas Mix 01-31-2013, 09:15 AM
Nighthwk12 Re: Toluene + Gas Mix 01-31-2013, 11:47 AM
dert Re: Toluene + Gas Mix 01-31-2013, 12:00 PM
addzradd Re: Toluene + Gas Mix 01-31-2013, 12:49 PM
Nighthwk12 Re: Toluene + Gas Mix 01-31-2013, 01:52 PM
acidcrashdburnd Re: Toluene + Gas Mix 01-31-2013, 01:25 PM
EJOUIE Re: Toluene + Gas Mix 01-31-2013, 01:31 PM
acidcrashdburnd Re: Toluene + Gas Mix 01-31-2013, 08:11 PM
addzradd Re: Toluene + Gas Mix 01-31-2013, 03:13 PM
Nighthwk12 Re: Toluene + Gas Mix 02-01-2013, 08:27 AM
dert Re: Toluene + Gas Mix 02-02-2013, 11:13 AM
Fivefingerdeathpunch Re: Toluene + Gas Mix 02-02-2013, 12:54 PM
  1. #1 Toluene + Gas Mix
    SE Level Member dert's Avatar
    Jul 2011
    Big Rapids, MI
    This is math anybody could do but i did it all today and figured i would share it. Hope somebody finds this interesting!
    Use at your own discretion, i haven't found a downside to using this but i have heard others warn against it so look up some facts make up your own mind first. also this is just one mixture that i was figuring for myself, your own numbers can be added in easily, my purpose is to show and explain the formula or give a general idea of the change toluene does.
    Toluene=114 octane
    Premium(by me)=91 octane
    Formula= (x*91)+(y*114)/x+y=desired octane
    where y= the amount of regular gas in mix
    and x= the amount of toluene in mix
    if say you want a 95 octane rating in 15 gallons of total mixture the formula becomes: (y*91)+(x*114)/x+y=95, y=15-x.
    skipping ahead a little: 1365-91x+114x/15=95
    comes out to: x=2.61
    plug x into the y formula you get: y=12.4
    So to get 15 gallons of 95 octane you need 2.61 gallons of toluene and 12.4 gallons of premium gas. (+whatever is in your tank though too keep in mind.)
    A little side note that is about 4.52ish a gallon for 15 gallons(with that mix at my local gas prices and changes with %toluene).
    I know a lot of areas have 93 or 92 octane premium too so you can easily just take this formula and change the 91 to whatever your gas is. Also getting 95 octane from 91 gas is adding 17% toluene which is a decent amount. Again do some research on it, from what i hear 30% is about the top you'd want, i cant personally speak to that so do a little research. This is my first writeup Hope somebody finds it useful! if anybody spots any mistakes let me know, i know i have it right on paper and i don't see any copying mistakes but you never know.
    There i got the excel spreadsheet in the zip folder if there is a better way let me know, but its pretty easy like that. Lotsa time into that let me know what you think!
    Only change the numbers in the top part. The bottom part of the spreadsheet are all formulas reliant on the top numbers. Also on the top numbers, you can only have 1 number be 0 at a time. You must enter a value for all but one and that one has to be 0. Thanks!
    Toluene + Gas Mix Attached Files
  2. #2 Re: Toluene + Gas Mix
    there's a bunch of 'home remedy' race gas mix recipes out there. maybe we should make this thread a little more in depth with those formulas as well?
  3. #3 Re: Toluene + Gas Mix
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Make this a plug and play program out of excel and you have a deal.
    97 Bonneville SE Not so much a 97 anymore
  4. #4 Re: Toluene + Gas Mix
    Jul 2011
    Big Rapids, MI
    Sure thing i have one! how do you upload excel files?
    And for what you said bio this formula will work for anything. You just figure out what the octane rating is of whatever you want to add and plug it in instead of the 114 octane rating of the toluene. All just one formula. But i agree i will try to find some other octane boosting chemicles used for gas and put the octane ratings on here along with the P&P excel spreadsheet!
    NVM on excel i got it uploaded inside a zip. file.
  5. #5 Re: Toluene + Gas Mix
    i've heard toluene, xylene, tranny fluid...lots of stuff as ingredients.
  6. #6 Re: Toluene + Gas Mix
    Nov 2009
    Central Jersey
    tranny fluid? odd. I can agree with toluene and xylene though pretty much any aromatic ring will boost octane. Cinnamaldehyde would be interesting.
  7. #7 Re: Toluene + Gas Mix
    Jul 2011
    Big Rapids, MI
    Excel spreadsheet updated!
    -Octane Number list
  8. #8 Re: Toluene + Gas Mix
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    That's great for bumping octane, but how does it effect tuning, what is the stoichiometric ratio for toluene, and how much specific energy does it have would you have to bump up injectors or timing?
  9. #9 Re: Toluene + Gas Mix
    Nov 2009
    Central Jersey
    Quote Originally Posted by addzradd View Post
    To put in very simple terms. Higher Octane mean more boost and more timing. It is not as much as having a higher energy fuel.
  10. #10 Re: Toluene + Gas Mix
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I have a Sunoco that sells 100 5 miles from a drag strip. which is 30 miles from me, and in the drag strip they sell 115.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  11. #11 Re: Toluene + Gas Mix
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Quote Originally Posted by acidcrashdburnd View Post
    How do you get a car to run on 115????
    Sorry, I have COD Zombies on the brain still.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  12. #12 Re: Toluene + Gas Mix
    Apr 2012
    Middletown DE
    Quote Originally Posted by ejouie View Post
    how do you get a car to run on 115????
    Sorry, i have cod zombies on the brain still.
    tune, tune, tune, tune.
    1993 Oldmobile 88
  13. #13 Re: Toluene + Gas Mix
    Feb 2010
    Cleveland
    Yes I know, but with e85 being 110 octane you cannot just go adding it to gas to up the octane number without re-tuning the engine. I am wondering if that is the same issue here since you would then technically be burning a different fuel.
  14. #14 Re: Toluene + Gas Mix
    Nov 2009
    Central Jersey
    Yes a re-tune would be needed or you are just burning really expensive fuel for no good reason.
  15. #15 Re: Toluene + Gas Mix
    Jul 2011
    Big Rapids, MI
    would running a small amount of something as in just enough to reduce a degree or two of KR still require a tune?
  16. #16 Re: Toluene + Gas Mix
    Quote Originally Posted by dert View Post
    Nope, if you were just trying to do it at a drag strip for a couple runs, there would be no use in trying to tune for it.
