my new deflector just came in 5 minutes ago now i get to go put it on:th_biggrin2:
Looks great, easy install! Sorry no pics. I got the one installed on my 99 GTP. I haven't done my other GTP yet or my dads GT.
Yeah, GM should of definatly did this to begin with. Why they designed it the way they did, we'll never know. (Actully I have my theory, its called "too much collage, not enough common sense")
Thanks for providing this for the community. Definatly a must have for any w-body...
Just joined the forum after recently purchasing a 2000 GTP. Could not believe I found a solution to the water problem immediately. I will take one as soon as they are again available.
OMFG, This is a GREAT FIX!
So easy to install!!!
Looks great, I feel Great about this!!!
1 thing, the cover over this deflector looks like it's raised now
Did I miss something? It's buckled upward a bit at the windshield.
Let me know, please
need one!!!!!
Probably doesn't fit perfect because it's not designed to fit '04 GPs. Sorry Abrasive, but I thought I read that he asked about '04s, and you answered that you didn't know if it fit. I check back to the 3rd page of this thread. Now you know!
I fitted it on one without issue. At least I thought, maybe I missed something. FastKatt, if there is an issue you aren't happy with, let me know and I will refund your money.
wow is it that easy bough my oo'grand pre used had this problem since day one! local dealer has no clue what to do. what do i have to do to get one??.... let me know!! total price and shippng to bardstown ky 40004 i dont care let me know
just to help you out they're 15 shipping and yes it is that easy to install. i've got it on mine. he's also got his paypal info on here i think. there's another post under the parts and demods section. but i think me may be out now and has to make more of them.
Thanks crshoveride.
Should have five more the first of the week. I'll put your name on one Chevydaddy and I think that will wrap it up for those five.
sounds good i'll be waiting
glad to help out abrasive and oh by the way i had the one piece cowl and i couldn't figure out how to take off the wipers but the cowl is flexible enough so i could install the deflector and i am very satisfied with the quality of it.:th_thumb-up:
This may be a stupid question but is this problem only with passenger side? Do you this part for the driver side because I am getting water on the driver side floor when it rains hard and I dont know where its coming from.
the only reason I can think WHY GM didn't recommend the replacement part is that it requires cutting the cover. Any modification like that might void a warranty, as simple as it is.
I see nothing that would be holding up my stock cowl...
The only thing I can think of is maybe it was warped up a bit and I never noticed it in the past?
I'm at a loss...
Anyway, we had quite a bit of rain day b4 yesterday, and my floorboard is dry as a bone!
Thanks again!!!
I guess that's possible, but if you are like me with your GP as I am with mine, you probably already know every little flaw beforehand. I guess with the wiper in the park position though, it does kinda hide the edge from direct view. I have seen cowls warp slightly over time, but your car is new enough that I wouldn't have thought that would be the case. Plus, the round retainer with the slot in it usually holds it down. I guess you could try loosening that retainer just a bit and see if that helps. The only thing I can think of is that with the original rubber deflector now gone, it might be possible to push that retainer down a little too far causing the cowl to sorta teeter-totter on the edge of the windshield glass and stick up just a little in that area. Again, this is just toatally a guess. ;)
I took a cell-phone shot of it fro the front, lifted
I'll try and get one from the window side showing the bowing
I'll post them both up, then you give me your opinion? Sound good?
