Thread: can i bypass the ignition switch to get heat
Results 1 to 19 of 19
  1. #1 can i bypass the ignition switch to get heat
    Nov 2008
    prince george
    no heater or defrost in my 2001 gp gt, ive figured its a bad ignition (no blower even at 5). can i bypass the ignition swith and just put in a toggle switch to get me by..Also does anyone have a wiring diagram for the heater . ive searched hi and low but cant sem to find one.. Any help here from you guys would be amazing thanks a bunch, it only -25c right now but it drops to the -30s soon enough.
  2. #2 Re: can i bypass the ignition switch to get heat
    Apr 2012
    Goderich, Ontario
    I think I got this same problem, when the heater doesn't work the headlights shut off too. I used Fog-X on the windows so they don't fog up. How hard is it to change an ignition switch?
    -Paul Walker
  3. #3 Re: can i bypass the ignition switch to get heat
    Nov 2008
    prince george
    i think its about a 2 hour job. I just don't feel like taking apart my steering console and dealing with the key tumbler and relearning the key. I found a power drop cable under the glove compartment and hooked my blower up to it. it worked but as soon as I drove home it quit so ill have to check some fuses today once I get my multimeter.. I was also wondering what color the power wire is for the actual heater .ac unit so I could just directly power the unit with a switch and bypass the ignition all together. if anyone has a wiring diagram id love to peak at it!
  4. #4 Re: can i bypass the ignition switch to get heat
    north carolina
  5. #5 Re: can i bypass the ignition switch to get heat
    north carolina
  6. #6 Re: can i bypass the ignition switch to get heat
    north carolina
  7. #7 Re: can i bypass the ignition switch to get heat
    north carolina
    hope these help man,can't have you freezing to death!,jimmy
  8. #8 Re: can i bypass the ignition switch to get heat
    Nov 2008
    prince george
    WHOOO HOOO!!! Jimmy you rock, !!
  9. #9 Re: can i bypass the ignition switch to get heat
    You can just hook up a toggle switch to the blower motor directly
  10. #10 Re: can i bypass the ignition switch to get heat
    FWIW on CGP there's a thread stickied on the how to and which wires. Works like a charm
  11. #11 Re: can i bypass the ignition switch to get heat
    Nov 2008
    prince george
    thanks guys, but i just lost the spare key to the car so now i cant even start it!!! lol!! Looks like its going to be a huge bill to have keys made and programmed. anyone ever bypass a pk3? maybe a pushbutton start?
  12. #12 Re: can i bypass the ignition switch to get heat
    north carolina
    damn it man!!lol sounds like a great time for a new ignition switch. take your registration card to nearest dealer and have them cut you a new key.
  13. #13 Re: can i bypass the ignition switch to get heat
    north carolina
    2001 pontiac grand am ignition lock replacement - YouTube
    ► 3:59► 3:59
    www.youtube.com/watch?v=Riw2zZaY4hc‎
    Jan 14, 2013 - Uploaded by mramericanmuscle40
    2001 pontiac grand am ignition lock replacement .... 99-07 Pontiac Grand Am/Prix Radio LCD Display Repairby Ryan96se5,347 views · 2:23 ... 2000 Pontiac Grand AM GT - CarProblemsby
  14. #14 Re: can i bypass the ignition switch to get heat
    north carolina
    Pontiac Grand Prix Key Stuck Permanent Fix - YouTube
    ► 2:33► 2:33
    www.youtube.com/watch?v=2rHbrsvzxWc‎
    Jun 4, 2011 - Uploaded by Sean Padden
    Pontiac Grand Prix GTP motorswapby RANS87IROCZ8,685 views · 11:55. Watch Later ... 2001 pontiac grand am ignition lock replacementby
  15. #15 Re: can i bypass the ignition switch to get heat
    north carolina
    2001 Pontiac Grand Prix - ProgramAutoKeys.com
    programautokeys.com/classified/DisplayAd.asp?id=1357‎
    2001 Pontiac Grand Prix - ProgramAutoKeys.com provides free programming instructions ... instructions for Automotive Keys, ChipKeys and Transponder Keys
  16. #16 Re: can i bypass the ignition switch to get heat
    north carolina
    wal-mart sells the transponder keys.
  17. #17 Re: can i bypass the ignition switch to get heat
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by 1fastam View Post
    Pretty sure they don't. Each key has a different frequency that it has to be set at. I'm almost positive you have to go to the dealer to get a key made.... unless you just want one that unlocks the doors. I could be wrong tho
    I went NA when a whore left -$300 in my bank account.
  18. #18 Re: can i bypass the ignition switch to get heat
    north carolina
    pretty sure they do indy i work there unfortunately,or atleast we have them here. they usually range from $35-$65 we have the reader also,jimmy
  19. #19 Re: can i bypass the ignition switch to get heat
    you need to call a dealer or go there with your title or registration to prove you own the car then ask for the key code. a lock smith can cut the new key for far less then the dealership would sell you one most of the time.
  1. Possible ignition switch
    By BillBoost37 in forum General Tech Discussion
    Last Post: 03-15-2013, 12:20 PM
  2. Ignition switch!?!? please help
    By Beelzeboul in forum General Tech Discussion
    Last Post: 06-11-2012, 04:19 PM
  3. Ignition switch!
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 06-01-2012, 05:09 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. Plug-N-Play Ignition Bypass Mod [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2008, 09:16 AM
