Thread: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS)
Results 21 to 40 of 49
  1. #21 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    Ok thanks
  2. #22 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Mar 2012
    NC
    No problem.
  3. #23 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Howell, NJ
    I want to hear a video or sound clip
  4. #24 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    SE Level Member phalanx's Avatar
    Mar 2012
    Barrie, ON
    Quote Originally Posted by Jomamma View Post
    +1
    wheres the vids?
    2002 Black Grand Prix GTP sedan - Go: SLP CAI & K&N Oiled Filter, Magnaflow catback, Overkill Tuned | Show: tint, GTP badge overlays, grill inserts
    2009 Maverick Silver Metallic G8 GT - sold...
    Bunnell, FL
    Quote Originally Posted by phalanx View Post
    +1
    wheres the vids?
    Plus tell two
    I'm a Sex Offender
  6. #26 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Topeka, KS
    Im not 100% for this idea but I would like to hear how much louder it actually is.
  7. #27 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Meh it looks legit, I have a spare blower I might try this with if I can remember where it is.
    Jan 2009
    Tallahassee, FL
    Nice work, but you're not the first. I saw someone on CGP do more or less the same thing with a plate.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #29 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    it's not louder at WOT at all. it's louder during part throttle where you're boosting maybe 3-5 pounds of boost.
    for the effort, and i've had them sealed on my car, i think it's a complete waste of time.
  10. #30 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    It's louder.
    ala, ported M90 here...
    XP Cam Start-Up - YouTube
  11. #31 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    SE Level Member 850Fishing's Avatar
    Jan 2012
    Florida
    sorry for the delay, here is a before and after from inside the car
    Before: 3.4 w/ supporting mods before Port and Polish - YouTube
    After: 3.4 w/supporting mods after Port and Polish with silencer plate - YouTube
    car ran good for 2 days then seems like a loss of power, realized it didnt like the tune i had from the intense 1.0 pcm, so i purchased hp tuners and been playing/learning with the tune, my maf sensor was way out of calibration from the new mods. I will say out of all the things i did to my car the hp tuners is by far the funnest. its amazing what changing some numbers in a few tables can do as for performance. i will post more vids after i get it tuned right.
  12. #32 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Jan 2012
    Florida
    Also had the low oil pressure idiot light in my dash on and hp tuners was reading my oil psi at -15. I just replaced the sensor 3 months ago so i figured it was still good. i have a light ticking that you can only hear at 2500 to 3500 rpm under load, figured it was a collapsed lifter that was not priming or a small exhaust leak at the cross over pipe to the rear headers. i pulled the idiot sensor out and taped a mechanical oil gauge in the port and mounted it in engine bay with new oil and filter 10w 30 syn. I was scared to start it and look at the pressure..... Cold start, idle in park it was at 60psi. THANK GOD!!!!!!!!! I still dont understand why hp tuners is reading my oil psi at -15. I purchased the mvpi standard new directly from hptuners.com for $540 shipped. does anyone on here have the standard mvpi on a 98 gtp with an oil pressure reading at -15?
    No factory oil pressure sender, no oil pressure in pcm.
  14. #34 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Apr 2009
    Fort Worth TX
    Like Matt says there is no sender it's just a switch. You're seeing the default reading in HPT.
    Jan 2009
    Tallahassee, FL
    That sender just tells the PCM when oil pressure goes below 15psi or so and flips the light on.
    77 Morris Garage B
  16. #36 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Jan 2012
    Florida
    Ok thanks, is there any downside to have the oil pressure switch deleted besides the oil cel will no longer work?
  17. #37 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    not really.
    if your oil pressure drops that low, you're kinda done anyways.
  18. #38 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    Jan 2009
    Tallahassee, FL
    Yea 15 psi and you're done. You can just plug the hole or get a oil pressure gauge and put the sending unit in that location.
    77 Morris Garage B
  19. #39 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    I live here. TLSheff's Avatar
    Nice write-up! Thanx
  20. #40 Re: Safely Filling Silencer Holes on ported Eaton M90 Gen III Supercharger with (PICS
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    I just had my ports welded shut by a shop they knows what they are doing. They are the best in the Cincinnati area, so if anyone in Cincy area wants this done they only charged 50 bucks. I thought this was reasonable since it is done with a nice pretty bead...lol. As soon as my damn motor is finished, I will post up a vid. The motor is done, just not in the booick yet..
  1. Eaton M90 Gen V supercharger problems
    By 05GTPcmpg in forum Off Topic Discussion
    Last Post: 06-04-2011, 11:20 PM
  2. Can I install eaton m62 supercharger on L36 engine?
    By SBB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 01:15 PM
  3. Filling supercharger slits and egr.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2009, 08:52 AM
