if you are having troublew getting into your car from the outside all your need to do is adjust the linkages.
open door and remove the plastic cover in the doorjamb behind the handle then locate the door handle linkage and then remove the clip holding it on there and unscrew the "nut" connecter thing and then re attach the connecter and clip to the door handle. its as simple as that
