Thread: Sealing off balance shaft oil hole.
Results 1 to 4 of 4
Threaded View
chico Sealing off balance shaft oil... 04-12-2009, 12:34 AM
SyntheticShield Re: Sealing off balance shaft... 04-12-2009, 08:03 AM
chico Re: Sealing off balance shaft... 04-12-2009, 11:13 AM
silvermistchick Re: Sealing off balance shaft... 08-09-2009, 11:22 PM
  1. #1 Sealing off balance shaft oil hole.
    Donating Users chico's Avatar
    This method is easier than drilling and tapping the oil hole left when you remove the balance shaft,just to reassure you that this method works I've just torn down my engine after a year with this in place and it's as good as new,were talking about the one oil hole in the bearing at the rear of the engine ,I use a 1 1/2" neoprene expand a plug found in the rad fittings and couplers at AutoZone this fits in the bearing just right and you tighten it up till it wo'nt move this allows you to maintain proper oil pressure and does not permantly alter anything ,Ive read all the other means of plugging this hole and this method is the best I've found,other methods are filling the hole with JB Weld,useing a cam bearing from a 440 dodge product and tapping it in,and the drilling and tapping method which works also ,this method just gives you another method and a method that can be done with the engine still in the car.Chico.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  1. Cubby hole to left of the steering wheel
    By RichCresci in forum Visual/Body Modifications
    Last Post: 01-29-2012, 12:47 AM
  2. hole in the intake plenum inside pcv housing??
    By Rick C in forum Introductions/Noob Questions
    Last Post: 02-15-2009, 06:03 PM
  3. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
  4. Corner Sealing
    By J_Man55 in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:04 PM
