Thread: Do It Yourself Spectre Intake with Pics
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Do It Yourself Spectre Intake with Pics
    MINNESOTA
    wow,nice post.going to have to do this soon.thank you
  2. #22 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    Quote Originally Posted by elhomero View Post
    I just realized this writeup that actually mentions the PCM. Removing the stock air box I have to secure the PCM down with velcro now?
    It's cold outside so I can't check under my hood right now.
    Velcro would probably be a good idea. I used zip ties but it really isn't ideal. None of the holes on the PCM line up with the holes in the body within reach of the PCMs harnesses.
    You can get sticky velcro kits just about anywhere. Just make sure you clean everything real well before you apply the velcro.
    7"
  3. #23 Re: Do It Yourself Spectre Intake with Pics
    SE Level Member elhomero's Avatar
    Aug 2011
    NJ
    Quote Originally Posted by industrialfish View Post
    Bah I accidentally deleted my old post. Velcro sounds like a better idea than the tray I see at 3800Performance. Where did you mount the PCM?
  4. #24 Re: Do It Yourself Spectre Intake with Pics
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    First DIY intake that actually looks good!! I hate the PVC intake BS!! Great job
  5. #25 Re: Do It Yourself Spectre Intake with Pics
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    Quote Originally Posted by copgtp View Post
    i made mine with pvc. painted it black and stickerized it
    All slow.. and no show
  6. #26 Re: Do It Yourself Spectre Intake with Pics
    Oct 2011
    Toledo, OH
    See the pic above? That's is about the only place you CAN put the PCM, it's on a pretty short harness. It was inside the airbox, so now it's just zip-tied to where the airbox WAS.
    7"
  7. #27 Re: Do It Yourself Spectre Intake with Pics
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    I got like a one and a half inch hose coming From something going into air box that the pics don't show what
    do I do with it?
    V
  8. #28 Re: Do It Yourself Spectre Intake with Pics
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by bandits grand prix View Post
    ur intake is fail because u still have the corrugated hose on the TB.
  9. #29 Re: Do It Yourself Spectre Intake with Pics
    Shut the front door, especially if the PVC tube goes farther up into the bent rubber tubing...then there is nothing to be "restrictive".
    Go mod your car, or get a resident card.
    Trolololol.
  10. #30 Re: Do It Yourself Spectre Intake with Pics
    SE Level Member KeepItKuminKid's Avatar
    Nov 2011
    Iowa
    How come when I did this to my 02 gt and I do wot it dies and shuts off.
    No check engine light or anything. Is it really grabbing that much more air that I need a tune?
  11. #31 Re: Do It Yourself Spectre Intake with Pics
    Quote Originally Posted by KeepItKuminKid View Post
    Pictures?
    What else did you do?
    Because you can remove the entire intake setup and run open MAF and it'll still run WOT.
  1. Spectre air filter or no?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 06-28-2011, 05:58 PM
  2. before and after intake pics! and vids!
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2011, 11:01 AM
  3. Spectre intake starting problems
    By dakcornholio in forum 04+ Specifics
    Last Post: 04-22-2011, 09:21 PM
  4. K&N vs. spectre
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-04-2010, 12:59 PM
  5. Short Ram Intake from Automat Central with Pics
    By RedLedbetter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2009, 03:44 PM
