Thread: 4th Brake Light (Under Decklid)
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 97
  1. #21 Re: 4th Brake Light (Under Decklid)
    SE Level Member kassel98gt's Avatar
    Howell,MI
    I also got one after I saw this post but I ran my wire through with the taillight wires so i dont need to drill and there isnt much chance for it to short out. i think the hole makes it look a bit better but more permanent.
  2. #22 Re: 4th Brake Light (Under Decklid)
    Centerville, Ohio
    Well I wired it all up ready to install and just about to drill the holes. I figured I'd test it just to make sure I had it wired right....and guess what.... the led strip was yellow, not red. I sent a message through Ebay to the seller and told them. Now I guess I just wait and see what they tell me. So now its gonna be another 2-3 weeks before I can get it all done. OWELL what can ya do.
  3. #23 Re: 4th Brake Light (Under Decklid)
    Centerville, Ohio
    Well my new and correct LED light finally came in. The weather here finally got a little better and we actully didnt have any rain today. So I installed the LED. I think it looks pretty good. The only thing I dont like is that Im not sure if the glue on the back of the LED is gonna hold. See what happens. Once I get her all cleaned up I will post a few pics. It was wasy to do it took about 20 minutes to get it all done from start to finish. Now to figure out this whole photobucket thing. Wish me luck
    Lattta
  4. #24 Re: 4th Brake Light (Under Decklid)
    SE Level Member GEMINIokc's Avatar
    Dec 2008
    n side
    would love to see the pics chase, good luck and if u do figure out the photobucket thing let me know , cause i cant figure it out myself :P
  5. #25 Re: 4th Brake Light (Under Decklid)
    GTP Level Member dstout's Avatar
    ky
    Quote Originally Posted by GEMINIokc View Post
    I just copy and paste from photobucket to the message and it works for me. You might try that instead of trying to attach the link in the message.
    Does this help?
  6. #26 Re: 4th Brake Light (Under Decklid)
    Dec 2008
    n side
    thanks dstout, so do you mean copy and paste the pic exactly? or the http: thing lol!! tried the http: thing that it gives you when you upload them to photobucket and it pastes this long address on my thread? also sorry to chase for using his thread on 4th brake lights to figure out my photobucket problem
  7. #27 Re: 4th Brake Light (Under Decklid)
    ky
    well what I do is open the pic in photobucket (don't copy the thumbnail the photo it needs to be the full size after you click the thumbnail), right click, click copy.......go back to the message, right click and paste. Your pic should appear in the message box.....then click preview post and see if it is there and then you can continue on with your message or post.
    Try that and see if it works.
  8. #28 Re: 4th Brake Light (Under Decklid)
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    my tape has held great so far chase... post up some pics
  9. #29 Re: 4th Brake Light (Under Decklid)
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    sweet!!!!
    hydro-powered
  10. #30 Re: 4th Brake Light (Under Decklid)
    Saint Louis
    whats positive and whats negative? Also, did the led strip come with enough wiring to run it the whole way without having to add any?
  11. #31 Re: 4th Brake Light (Under Decklid)
    Centerville, Ohio
    No the led strip only comes with about 3ft of wirind if that. So yu neeed to run a longer wire. As far as the polarity, it will only work one way. If the polarity is not right it wont work, then just switch the wires around. BTW im still working on getting those pic online. I have to wash my car first. I can see the critizism comming if my car is dirty. LOL Maybe I ll wash it this week and get them out.
  12. #32 Re: 4th Brake Light (Under Decklid)
    Howell,MI
    has any one had trouble with their led strip losing lights?
  13. #33 Re: 4th Brake Light (Under Decklid)
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    Guys, I found this strip at ebay but it comes from Honk kong... I really don't trust to buy item from outside of usa..... do you know where else can i find this led strip???
  14. #34 Re: 4th Brake Light (Under Decklid)
    canada
    hmmm. looks like a good job done, my personal opinion is that a fourth brake light is redundant. BUT that said it is done nicely and if u the driver likes it then ride on my friend ;-)
  15. #35 Re: 4th Brake Light (Under Decklid)
    Roanoke, VA
    looks great as for the turn signs they make a unversial one for trucks that have them.
  16. #36 Re: 4th Brake Light (Under Decklid)
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Anyone else have pics of this mod on their cars?
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  17. #37 Re: 4th Brake Light (Under Decklid)
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I just bought a "fire and ice" tail bar met for large trunks. I plan on cutting it to the proper length and fitting it under the deck lid. I also wanted to have turn signal functionality and backup light functionality as well, so I bought a two piece fire and ice set. I am really hoping it will fit well and I will post pics of the finished product.
  18. #38 Re: 4th Brake Light (Under Decklid)
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    super old thread but ive had the same idea lately, i didnt know that others have done it too. my plan was to get 2 12" amber and 1 24" red and maybe even 2 2" white and do a whole spread across the back of my car, red and white in middle and then amber on my tails in the groove
    so it would be from (L>R) amber white red white amber
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  19. #39 Re: 4th Brake Light (Under Decklid)
    Quote Originally Posted by iroc2 View Post
    Hmm, I mean functionality I think it would work fine, but idk how it would look with all those wires ruining inside your trunk as well as the back of your car because of all those different colors. Also, and this is just me, do you want ambers on the back of your car? The only reason i ask is because I don't think your GP has amber rear turn signals, just a brighter red, correct? May look kinda goofy to have a amber thrown in there, maybe something to think about.
  20. #40 Re: 4th Brake Light (Under Decklid)
    Jul 2010
    Lansing IL
    Quote Originally Posted by chamilton89 View Post
    im not worried about the wires, im kinda anal about lots of wires everywhere so i would make it as clean as i possibly can and the wiring "invisible" and hidden. and yes i do have amber turn signals. otherwise i wouldnt even bother with them lol. no worries tho i understand exaclty where you are comming from and how 97+ are all just through the brake light instead of a whole seperate turn signal circuit such as on the pregens. i got he turn signal idea after seeing how the under fire(im pretty sure i got he brand name wrong) light bars under the tailgates of trucks started having the turn signals. im not sure if one of those would fit. depending how how everything prices out i may look into the truck lightbar and see if i could modify it to fit or somehting. there will deffinately be a write up when i do it
    im about to begin looking into strips.
    the bottom of my trunk is 30"
    *option a: so im thinking a 24" with a 3" white on each side (24+3+3=30)and then a 12" amber on the taillight. a 20" would be more than adequate as it would wrap around to the side and go to the front of the taillight.
    *option b: im also wondering about id i matched up the leds with the taillight and did red at the bottom of my trunk 30" and hten 4" on each taillight above my reverse lights, and then a 16" for the blinkers, going to the front of the taillight.
    any input? im thinking the second idea would look better since the groove goes around the sides and to the front of the taillights
  1. Shaved Decklid Lock...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 07-18-2008, 10:03 AM
  2. KVR big brake kit
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2008, 07:00 PM
  3. parking brake light???
    By kingd44 in forum General Tech Discussion
    Last Post: 02-20-2008, 11:38 PM
  4. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
