Thread: How to fix a Regal Century dim cluster or DIC
Results 1 to 13 of 13
  1. #1 How to fix a Regal Century dim cluster or DIC
    The Regal and Century's have a problem where the odometer will become dim and nearly impossible to read at anytime of the day/night. Some Regal were equipped with a cluster that had a DIC or driver information center that can suffer same problem. To fix this you will need to remove the dashboard bezel to remove the cluster. Then open the cluster and solder some 1/4 or 1/2 watt 150 ohm resistors on the cluster circuit board.
    Open both front doors
    Remove the end panels of the dash (on passenger side this is the fuse cover.
    On the passenger end, remove one 7mm screw from end of dash trim panel.
    Open glove box door
    Remove one 7mm screw from the lower dash panel that is to the right of glove box door.
    Pull that lower dash panel toward the seat quickly and the clip will release.
    Remove the driverside lower dash panel by tilting the wheel all the way up and removing the two or three clips/7mm screws holding it at the base of the dash.
    Pull that forward/upward like the small piece on the other side. Unplug the wiring to the button pod on the piece.
    Start at the passenger side pulling the dash panel forward to unclip it. You will notice it is behind the piece of the center console. Work past this to the driverside. When all the clips appear loose, wiggle and jockey it to get past the center console.
    Remove cluster by pulling out four 7mm screws that hold it in and then unclipping the connector that goes to it.
    Needed:
    Soldering iron
    10 or less 180 ohm resistors. (1/4 watt or 1/2 watt, either will work well)
    To open the cluster gently pry the black back off the cluster by lifting gently on the black piece at the arrows. Usually lifting two or four is all it takes for it to come off.
    Here are the two pieces.
    Grasp the circuit board and wiggle, it will seperate from the rest of the cluster.
    Put your black back piece and main cluster piece off to the side and out of harms way. Place the circuit board on a towel or other item that will not hurt it. Looking at the circuit board there should be barrel resistors in the circled areas. If you touch them, likely they will crumble and fall off. Remove them if they are there. (Century and non-DIC Regals will have fewer than this picture, only replace ones in the circled areas)
    (Note: prefix pic not available.
    Now solder your new 180 ohm resistors onto the board where the old ones were. I only have experience with 97/98 clusters, they have traces and holes through the board for most of the resistors where you can hold an iron to a solder dot on the back of the board and push the resistor through. If you have this style circuit board, it is easier. Here is Rick (DeMonte) demonstrating. It is his first time and it came out great.
    Here are the remainder of the resistors in place
    4 here
    4 here
    And 2 here
    Reassemble your cluster by pushing/wiggling the circuit board back on the main cluster and then pushing the black back piece back onto the cluster.
    Plug it in and try it before you reassemble the dash.
  2. #2 Re: How to fix a Regal Century dim cluster or DIC
    Jul 2011
    Ed
    I have a 1998 Buick regal gs. The DIC doesn't light up anymore and more recently, the odometer was stuck in metric. I replaced the button assembly that controls the odometer, and it's still stuck in metric. Would this method of fixing the DIC possibly fix the odometer as well?
  3. #3 Re: How to fix a Regal Century dim cluster or DIC
    The dimness would get fixed by doing this resistor swap. The metric issue is likely a wire being grounded out. The button assembly either grounds or interupts ground to the cluster and hvac unit to turn them metric/US.
    Don't have the schematic on me at themoment, but uh.. hmm I might have it handy though.
  4. #4 Re: How to fix a Regal Century dim cluster or DIC
    Jul 2011
    Ed
    I will do the resistor swap. Any other info on the odometer would be much appreciated!
  5. #5 Re: How to fix a Regal Century dim cluster or DIC
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Hmmmm could I fry the board this way? My odometer doesnt light up at all anymore and have zero sodering experience. Could I just replace the whole board and the same miles show up? Thanx ahead Billyboost
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  6. #6 Re: How to fix a Regal Century dim cluster or DIC
    Same miles wouldn't show up. If you aren't comfy soldering. Ask around to your buddies. This is a fairly straight forward thing to do.
    If you wanna send it to me, I can do it.
  7. #7 Re: How to fix a Regal Century dim cluster or DIC
    Oct 2008
    IL
    So by the pictures its just sodered right to the board as long as it on the same "circut". Mine has holes too I just dont see how the holes would match up.
  8. #8 Re: How to fix a Regal Century dim cluster or DIC
    Then pull the old ones off and add right to the pads where they were located.
  9. #9 Re: How to fix a Regal Century dim cluster or DIC
    Oct 2008
    IL
    Did tht worked great
  10. #10 Re: How to fix a Regal Century dim cluster or DIC
    Glad it worked out for you.
  11. #11 Re: How to fix a Regal Century dim cluster or DIC
    Nov 2011
    Michigan
    Hi billboost..
    Awesome information.
    I love this kind of sharing.
    Will this repair work on the slightly newer Buicks as well?
    2003 Century? Must still be same cluster?
    Thanks again.
  12. #12 Re: How to fix a Regal Century dim cluster or DIC
    Oct 2008
    IL
    "The Regal and Century's have a problem where the odometer will become dim and nearly impossible to read at anytime of the day/night. Some Regal were equipped with a cluster that had a DIC or driver information center that can suffer same problem." He says its a Century issue too. Easy to take out AND you can drive without the cluster so not like you can get to work if you have to.
  13. #13 Re: How to fix a Regal Century dim cluster or DIC
    Yes..this applies to all Regal/Century's from say 97-04.
    Century is a little easier because it has about half the resistors IIRC .
  1. Gauge cluster
    By monsterjam5000 in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2010, 09:04 PM
  2. 05 GXP Cluster in 04 GTP
    By xerxescct in forum General Tech Discussion
    Last Post: 09-30-2008, 03:50 PM
  3. Need a 1998 Buick Century Bin File
    By buickman104 in forum PCM Tuning
    Last Post: 08-19-2008, 10:22 PM
  4. Hi. Noob with a 98 Buick Century.
    By Hood_Shield in forum Introductions/Noob Questions
    Last Post: 04-16-2008, 11:43 AM
  5. Century mods...
    By Hood_Shield in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-27-2008, 11:01 AM
