Thread: Increase keyless entry range
Results 1 to 20 of 29
  1. #1 Increase keyless entry range
    Omaha, NE
    I haven't tried this yet, but I don't see why it wouldn't work.
    ‪Amazing Car Remote Mod!‬‏ - YouTube
  2. #2 Re: Increase keyless entry range
    Kansas
    I literally bought a new fob casing w/ rubber buttons off ebay for 6 bucks.... it works ridiculously a lot better and farther out now.
  3. #3 Re: Increase keyless entry range
    Windsor (ON) Canada
    Same.... my fob SUCKS! I have barely any range. I may just try this out.
  4. #4 Re: Increase keyless entry range
    Windsor (ON) Canada
    Found this pic online... what would you say is our antenna?
    That Black square??
  5. #5 Re: Increase keyless entry range
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    i wonder how far it would work if you soldered a 6 foot wire too it..
  6. #6 Re: Increase keyless entry range
    Kansas
    The bigger in the upper left.
  7. #7 Re: Increase keyless entry range
    Windsor (ON) Canada
    Quote Originally Posted by NegativeOne13 View Post
    For real? that looks like plastic, and hense nothing I can solder on
  8. #8 Re: Increase keyless entry range
    Kansas
    Quote Originally Posted by Colossus View Post
    Oh **** my bad, I took a closer look and yeah... thats not the antenna.
  9. #9 Re: Increase keyless entry range
    I like knowing i can't unlock my car from inside my house by accident.
    Then wake up and have all of my change missing.
  10. #10 Re: Increase keyless entry range
    Quincy, Mass
    i believe this is the antenna
    No more GP 04 Impala SS Indy:
  11. #11 Re: Increase keyless entry range
    Bunnell, FL
    just because his nissan keyfob has a metal antenna module doesn't mean ours is
    ours is the plastic one mentioned above. only way to so this mod would be to see if the range worked if you hit a solder point, but i highly doubt that
    I'm a Sex Offender
  12. #12 Re: Increase keyless entry range
    Windsor (ON) Canada
    That gold square? I tried a bunch of combinations with no success. I think those quares are just to complete the circut for the battery because the middle of the bettery touches the black square and the little metal tab on the other piece of the fob touches that gold square. I may be wrong, but kinda done with trying this unless someone else does
  13. #13 Re: Increase keyless entry range
    PA
    Consider extending the antenna of the receiver instead of the fob.
    2001 GSE
  14. #14 Re: Increase keyless entry range
    Donating User Odi's Avatar
    Chicago South Suburbs
  15. #15 Re: Increase keyless entry range
    May 2011
    Bremen,GA
    Try an aftermarket keyless entry with 900 MHZ frequency.
    They have amazing range without being in line of site.
    We started our company van from a hotel elevator in LasVegas.
  16. #16 Re: Increase keyless entry range
    Quakertown, PA
    On this particular keyfob, I am pretty sure the antenna is the printed circuit trace that runs around the outside of the board. In the picture, you can see one trace that has lots of holes in it. This would be the ground plane side. The other trace that comes out of the circuitry in the upper left side of the picture and runs around the perimeter of the board on the left side is the "hot" side of the antenna.These traces are "tuned" to the frequency of the transmitter and lengthening or shortening them would probably just "reduce" the range, not increase it since you would be de-tuning the antenna. In other words, put in a fresh battery and leave the transmitter alone. As someone else said, you might be able to increase the range if you could add a better antenna to the receiver but I don't even know where the receiver is located on the car....does anyone know?
    '02 - 3.8(K) 153,000 miles, New UIM, New LIM alum. gasket, new lifters, new OEM cat. Runs great ! Owned it since new. (bought it 12 years ago with only 22 miles on the clock)
  17. #17 Re: Increase keyless entry range
    Windsor (ON) Canada
    ^iiiiiiinnnnteresting.
    ps... i give up
  18. #18 Re: Increase keyless entry range
    PA
    ps... i give up
    Why do you give up so easily? BackinBlack talked about increasing the antenna on the receiver. I don't remember exactly what it was, but I think you had to measure the antenna, then lengthen it in multiples of 4 or something weird like that. Do some searching and find it.
    2001 GSE
  19. #19 Re: Increase keyless entry range
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Per the video:
    "Anyone with basic electronics knowledge knows
    1) That is a crystal and not the antenna
    2) Soldering to the crystal is a bad idea
    3) Soldering to the antenna would be a worse idea as it would detune it."
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  20. #20 Re: Increase keyless entry range
    SE Level Member Wraith888's Avatar
    Twin Cities
    Did anyone make any progress with this?
  1. fix my keyless entry!
    By foursixer in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2011, 07:20 PM
  2. Keyless entry
    By zildjian102 in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 09:14 AM
  3. 94 keyless entry
    By eeltam in forum General Tech Discussion
    Last Post: 01-05-2011, 05:49 PM
  4. No keyless entry!
    By tmackster in forum The Rant Forum
    Last Post: 07-22-2009, 02:44 PM
  5. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
