Sanding the exhuast tips. Under $30 if you want to really want to slowly change the grit.
Does anybody else see this thread leading to more ricers in GPs than we already have?
I made gutter guard grills for my first grand prix... It took under $10 in gutter guard and a couple zipties. I used snips to trim the gutter guard and cut the hell outta my hands so wear gloves if you're going to attempt this.
Doesn't an EGR delete require a tune? So... $150, at the cheapest?
You don't have to do a tune for egr delete as long as you can live with the CEL.
LED interior lights for the floor board ~$25 to do the whole interior and a switch. Parts can be acquired at autozone/walmart...
Disable drl's
Interior LED's. If you ebay the parts, its around $50 + i had a spare led for my license plate light. And its so bright inside.
My state doesn't have emissions, so I don't know.
If you know someone with DHP, they could remove the code for you for free, and you should be good to go.
Weight reduction![]()
pry it off.
sure.
I pulled it off with my hands.
