Thread: How-to delete EGR.
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 How-to delete EGR.
    Feb 2008
    Instructions: Unplug EGR valve from wiring harness. Unbolt EGR inlet tube from exhaust manifold (13mm). Unbolt EGR outlet tube from lower intake manifold (13mm). Unbolt two bolts holding the EGR valve pedestal to the head (13mm or 15mm). Remove entire EGR system from engine bay! Finally, find a way to seal the two holes you have just exposed. You should have something that looks like the picture below. Notice that the inlet tube is cut. That's how I got the collar off (it had a leak next to the inlet, anyway).
    You'll have to either make or buy block-off plates or have the holes welded shut. I placed a penny in the old retaining collar to cover the hole from the exhaust manifold and RTV'd it to make sure it would seal, then I bolted it in just like the original EGR inlet tube. Next, I made a block-off plate out of a piece of sheet steel to bolt to the LIM. Put a little RTV around the hole, and bolt 'er down! Of course, now I have the hole blocked in the blower casing, too.
  2. #2 Re: How-to delete EGR.
    GT Level Member Joe m's Avatar
    mesa,az
    Iv never heard of deleting a egr before. What exactly happens when you delete the egr? And would you need to tune for it after its gone?
  3. #3 Re: How-to delete EGR.
    Feb 2008
    With no EGR, the exhaust is no longer being dumped back into the intake. Therefore, your intake stays cleaner, and, for some vehicles, you no longer have part throttle knock. If you completely remove the system, you will have to tune for it. If you want to, you can just set the system up so it still works, but sucks in fresh air, instead of exhaust gas.
  4. #4 Re: How-to delete EGR.
    mesa,az
    can you still pass emissions with a deleted egr?
  5. #5 Re: How-to delete EGR.
    Banned - Busted For Scamming
    Feb 2009
    nope
  6. #6 Re: How-to delete EGR.
    yes you can if the code is set to no report. i did it more than once.
  7. #7 Re: How-to delete EGR.
    Feb 2008
    As long as they don't pop the hood and search for it (they rarely will) , you're fine.
  8. #8 Re: How-to delete EGR.
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    Quote Originally Posted by DanGTP View Post
    suck in fresh air? you runnin the suction of the egr thru a filter? that's the first i've heard of settin it up to suck fresh air..
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  9. #9 Re: How-to delete EGR.
    Portland Oregon
    Quote Originally Posted by mikesarebetter View Post
    You just dis-connect and block off the exhaust side of the egr on the manifold and leave the tube hanging just sucking in fresh air.
  10. #10 Re: How-to delete EGR.
    Spearfish, sd
    seems kinda silly... isn't that just like runnin with no air filter but on a smaller degree?
  11. #11 Re: How-to delete EGR.
    GT Level Member WHT98GTP's Avatar
    Monroeville
    I just deleted my egr because it kept throwing codes on me. I welded the exhaust hole closed, and i filled the hole in the lower manafold with jbweld. Worked like a dream...I always thought that egr systems are retarded...When i rebuilt my m90, my lower intake was jet black inside form that cap. :-( A quick tune and all the codes are gone. FTW.
    *2002 Buick LeSabre Custom* Bronzemist Metallic * SS Headers *4" FWI*
  12. #12 Re: How-to delete EGR.
    Portland Oregon
    Is there any other tuning involved other than setting the egr codes to no report?
  13. #13 Re: How-to delete EGR.
    Monroeville
    Not that i know of. All i did was shut off all the codes related the the EGR system, thats it.
  14. #14 Re: How-to delete EGR.
    Feb 2008
    I bought one of those "ricer breathers" from Auto Zone and stuffed it on the open tube.
    I was able to add a little part-throttle timing due to not having the EGR. Later, when I completely removed the system, my MAF was a touch off, so I did a bit of fine tuning there.
  15. #15 Re: How-to delete EGR.
    Portland Oregon
    Sweet. There's something I might do after I get a tuner next year.
  16. #16 Re: How-to delete EGR.
    GT Level Member 02gtpsleeper's Avatar
    Hanover Park, Illinois
    u have to remove the oil cap and put breather on that. Keep pressure down.
    http://www.zzperformance.com/products_img/1094_2.jpg like that one
  17. #17 Re: How-to delete EGR.
    Feb 2008
    Quote Originally Posted by 02gtpsleeper View Post
    Ummmm... Not that I'm aware of. That would be if you make the PCV system in-operable by adding an intercooler that blocks it.
  18. #18 Re: How-to delete EGR.
    GTP Level Member tazyboy28's Avatar
    home town
    i put a small filter on the opening for my egr to recirculate the exhaust. and im getting a P0402 code. is that something i don't really have to worry about.
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  19. #19 Re: How-to delete EGR.
    SE Level Member sonyz92's Avatar
    Alfred, New York
    so if i just disconnect the EGR outlet from the exhaust manifold, put a filter on it and seal the hole in the exhaust manifold, it will be sucking clean air and i wont have to worry about any codes?
  20. #20 Re: How-to delete EGR.
    Feb 2008
    Quote Originally Posted by sonyz92 View Post
    Correct
  1. delete please
    By gotboost3 in forum How To Write-Ups/Tech Tips
    Last Post: 08-30-2009, 01:14 PM
  2. Delete
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2009, 03:56 PM
  3. EGR Delete
    By Feather Head in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 04:09 PM
