Thread: 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
Results 1 to 9 of 9
  1. #1 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    This How To write-up on Transmission Sprocket Ratio Swap has been added to the HOW TO section and can be found HERE.
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Very well written write up Dave. I would like to tear into a tranny sometime, just so I can see what is inside and maybe learn something. You have made me think twice about not building my own tranny. Maybe I will contacting you this spring
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
    Oklahoma
    Dave, WOW! You're just gonna make me cry with all this wonderful information. Its like giving crack to a drug user, LOL
    Thank you again so much for your sacrifice here bud. I will never be able to express it well enough or say it enough but I appreciate all that you are doing?
    You got anything else on the plate we can be looking forward to?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    That write-up is a work of art. Thanks for sharing Dave.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    newark
    i would like to ask if the tcc shift silonoid can be replaced with the tranny in the car through the pan or does it have to be done with it pulled on the 96 model 4t60e thanks
  6. #6 Re: 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    richmond
    very impressive tranny many... have some questions myself if you wouldnt mind answering them. i have a 2003 gtp n the trans went on it friday. was wondering what the best solution would be and some prices.. not looking to spend a too much... maybe 1500. i was wondering how hard it is to rebuild one of these myself?
  7. #7 Re: 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    Mar 2015
    Confederate States of America
    Is there a new location for this link? Nothing but a blank page found.
    Quote Originally Posted by Trannyman95 View Post
  8. #8 Re: 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    Nov 2013
    United States
    Bump. Update the link Please.
  9. #9 Re: 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    Feb 2013
    Missouri
    Yea, good luck with that. Pretty much just follow this and ask any questions you might have:
    http://www.grandprixforums.net/threa...e-cover-access
  1. 1986 Oldsmobile Cutlass L67 Swap
    By Trannyman95 in forum Transplants
    Last Post: 08-22-2012, 04:29 PM
  2. Top Swap Section
    By indy99gpgt in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 05:53 PM
  3. 1992 Cadillac STS L67 Swap
    Last Post: 12-13-2007, 04:34 PM
  4. 4T65E Trans Info Link
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2007, 04:01 PM
