yeah..there's ways.
Jayke..I'll trade ya.. pinouts fro everything for ....yep.. low cost and high quality.
yeah..there's ways.
im waiting on the reply lol he hasnt respnded yet you mooly
pinout the same on a 97 as would be on the 98?
simon
97 and 98 PCM pinouts are different. Both are posted above.
The fuse box may be very similar, however.
Sent from my SAMSUNG Infuse using Tapatalk 2
it states 97 and 99. if 97 and 98 are different, then perhaps you are guiding me towards a 98 and 99 pcm being the same, would this also be for a 2000?
not trying to make things hard, just trying to keep things strait.
simon
Oops... My apologies. The 98 & 99 should be the same. From what I recall, the PCM's are physically interchangeable from 99-03. Based on that, I assume that the pinouts are also the same. Basically, 97 was the red-headed step-child of the GP family.
sounds good, thank you
I have a 2000 GP GTP. Can someone post the pin outs for the PCM for this year? The thread implies that it should be the same for 1999 which was posted but I believe there are differences. For example, for 1999 it says that pins 1 and 2 are unused but I have some info that for 2000 pin 1 is "Trans Fluid Temp Sensor Signal Ground". Also it says that pins 10-14 are unused but my info says 10, 12 and 13 are used. Trying to get confirmation on data I have but don't have full pin set for C2. Thanks.
