Thread: Heater Core Replacement 97-03
Results 1 to 13 of 13
  1. #1 Heater Core Replacement 97-03
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    You will need a rachet with some long extensions and have the shifter in low
    Undo the ruber hoses coming out from under the metal lines and coolant will come out, but not too much
    Take the center console out, there will be bolts under it
    Now take the top plate off, unscrew it from the shifter and under the radio then pull the whole console backwards and it will come out past the shifter.
    Take the ugly carpet pieces near your feet off and undo all the gold srcews for the heater core cover. Removing the cover is the part that gave me the most trouble, I ended up cutting the duct that goes under the carpet and pulling like crazy to get it out (hint: take it out the drivers side)
    You will see this after taking out both plastic pieces
    Now pull it out by holding on to the top and bottom and reuse the clip at the back
    Reverse to put back together
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  2. #2 Re: Heater Core Replacement 97-03
    GTP Level Member
    springfield IL
    nice!! hope i never have to have this done!!!!!!
    lol
  3. #3 Re: Heater Core Replacement 97-03
    Spring Lake, Mi
    haha, I wish I never had to
  4. #4 Re: Heater Core Replacement 97-03
    Jun 2011
    Mid Michigan
    Nice write up on removing the AC condenser. Did you actually continue on to the heater core?
  5. #5 Re: Heater Core Replacement 97-03
    Jun 2011
    Mid Michigan
    Oops my bad. Used to be if it was aluminum it was AC. Glad it was the heater core as it looks like the evaperator would be a real job.
  6. #6 Re: Heater Core Replacement 97-03
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Isn't that the A/C condenser that you removed?
    For all your 3800 needs:
  7. #7 Re: Heater Core Replacement 97-03
    Spring Lake, Mi
    nope, unless the haynes repair book is wrong
  8. #8 Re: Heater Core Replacement 97-03
    Michigan
    Thanks for the write up. I will use this as a loose guide to change the heater core in my 2006.
    Wife: Your car feels just like mine.
    Me thinking: You didn't step on the gas enough to feel the supercharger.
  9. #9 Re: Heater Core Replacement 97-03
    Spring Lake, Mi
    It should be almost the same, but if you have any questions on it, shoot me a pm
  10. #10 Re: Heater Core Replacement 97-03
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    I can't really tell from the pictures.. but is the heater core in the center or toward the passenger side of the car? I have a leak coming from the passenger side.. I thought it was the heater core.. I had a nice puddle in front of my passenger seat and it turns out i'm low on coolant... it looked like just water but i think that's all that's in my radiator since i just bought this one...
  11. #11 Re: Heater Core Replacement 97-03
    Spring Lake, Mi
    Heater core is in the middle but what that could be is where water will leak in past a plastic shield thing. Just search about water on the floorboard and you will find it
  12. #12 Re: Heater Core Replacement 97-03
    SE Level Member dominator22's Avatar
    Jul 2013
    Clarkston, MI
    Thanks a lot, sadly I am doing this tonight.... The heat got to her.
  13. #13 Re: Heater Core Replacement 97-03
    Jan 2013
    canada
    wanna come by and do mine? lol
  1. heater core
    By gtpinsc in forum General Tech Discussion
    Last Post: 04-01-2011, 12:29 PM
  2. heater core
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 10:24 PM
  3. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  4. Heater core replacement....
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-19-2008, 10:10 PM
  5. Heater Core
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 08:58 AM
