Thread: Everything you ever wanted to know about auto dimming rear view mirrors
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 Everything you ever wanted to know about auto dimming rear view mirrors
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    Seeing as to how I'm frequently asked about information on self-dimming mirrors, I thought it would be a good idea to start an informative thread outlining how the mirrors work, the different brands and kinds there are, the pros and cons to those different kinds, as well as basic removal and installation instructions. My goal is to make this as thorough as I can, but if you still have some questions I didn't go over, please feel free to ask. I'm not an expert by any means, but I've been fascinated by these mirrors ever since I discovered them 10+ years ago, so I have gathered a decent amount of information about them. Forgive the quality of the pictures. I will update this post when I get a better camera and more ideal lighting.
    Quick History & Background
    Auto-dimming mirrors are nothing new by any means. The electrochromic technology used to make today's mirrors has been around since the '40s, and has been in use in automotive mirrors since the '80s. The concept of an auto-dimming mirror was first introduced by the Zeeland, Michigan based electro-optical products manufacturer Gentex Corporation. They created the world's first electromechanical mirror in 1982, which found its way into higher end American luxury cars as an option in 1983. It used sensors to detect glare from behind. The sensors were connected to a small motor that would move the angle of the mirror to adjust accordingly. In other words, it basically acted as an automatic version of the flip tab on standard mirrors. These mirrors would be available through '91.
    In the meantime, a father and son team of chemists convinced Gentex that they knew how to apply electrochromic technology (a gel that darkens when electrically charged/clears with no charge) to their mirrors. After investing a lot of money for R&D, they found a way to sandwich a thin layer of the gel between 2 pieces of glass, and have it react to an electrical charge initiated by sensors mounted on the front and rear of the mirror when they detected glare. The first electrochromic self-dimming mirror was introduced in '87, and was made available in the '88 Lincoln Continental, and 8 GM cars in '89. They became more commonplace in the early '90s.
    It is at this point that Holland, Michigan based Donnelly Corporation, another major automotive mirror manufacturer, came into play. Gentex' auto-dimming mirrors were a huge success, gaining more and more car manufacturer contracts. Donnelly was trying desperately to take back some of the market share by producing mirrors with very similar technology. In may of '90, Gentex sued Donnelly over patent violations. Through a mess of suits and counter suits over the next few years, as well as out of court settlements, things finally cooled down between the companies. In the meantime, Gentex continued to expand upon what they started with their mirrors. In '93, they introduced the first self-dimming mirrors with a compass that showed the direction you were headed in a little digital display within the mirror itself. These mirrors would become available on '94 model year luxury cars. From '97 - '98, cars would start receiving self dimming outside mirrors, inside mirrors that displayed compass as well as outside temperature, and compass mirrors with LED map lights, which were ONLY available as an option on the Intrigue GLS in '98. The GLS also had this same mirror available in an OnStar equipped version.
    Fast forwarding to today, Gentex has grown immensely, and is regarded as the leading company in auto-dimming mirrors with distribution in several countries, including Germany and Japan. They have expanded their contracts to almost all car manufacturers around the world, and self-dimming mirrors are no longer something reserved for higher end luxury cars. They can be found in all sorts of makes and models in many variations. The features have also increased dramatically, including versions with HomeLink, back-up camera and navigation. Meanwhile, Donnelly lost a lot of ground in the war for market share since 2000, and is virtually non-existent in the manufacturer's contract department.
    Gentex vs. Donnelly Pros & Cons
    Being the 2 major producers of auto-dimming mirrors, these two have been dueling each other for a couple decades now. Virtually every feature Gentex came out with, Donnelly would copy. However, the 2 companies took a very different approach as far as aesthetics. Donnellys had more of an "egg shape" to them, especially if they had temp and compass, because they put the display for those in the base of the mirror as opposed to in the mirrors themselves like Gentex does. The front of a Gentex mirror looks more like traditional mirrors, but with a bit of an extension at the middle of the bottom for the buttons. Personally, I prefer the way Gentex' look a lot more, but that's subjective. One plus for Donnelly mirrors is that they are much more commonly available with map lights. Since most of the vehicles that Gentex' originated in were luxury, or well equipped, they usually already had some kind of fancy overhead console or dome light, so they scarcely received map lights in the mirrors.
    Fully optioned Donnelly mirror.
    However, this and all other advantages for Donnelly mirrors are a moot point because of one monumental problem they're prone to which renders them useless. Donnellys are notorious for breaking and leaking the liquid inside of them, often causing discoloration in the paint when the liquid eventually drips onto the center console. Why is not completely known. However, I mentioned the legal troubles between the 2 companies earlier, and that Donnelly had to change their methods of accomplishing the auto-dimming effect due to patent infringements. My theory is that whatever they did to change the process for auto-dimming, it was an inferior process with poor reliability/durability. On the other hand, I've never really heard of a Gentex mirror failing in any capacity (certainly not by leaking out the gel). It is for this reason that I usually suggest people switch to a Gentex when their Donnelly mirrors finally fail, which they inevitably will.
    Mmkay, now for the good stuff you've been waiting for.
    Removing and installing auto-dimming mirrors
    Removing factory auto-dimming mirrors from the windshield
    *DISCLAIMER: The process for removing mirrors with the newer mounting style can put your windshield at risk for cracking or breaking. I am not responsible for any damage. Attempt at your own risk!
    This will actually be the hardest part of adding/replacing an auto-dimming mirror. Rather than using the traditional, easy-to-remove single torx screw to tighten the mirror onto the windshield button, newer auto-dimming mirrors have a tensioned spring with tabs in the brackets that, once the tabs clear the windshield button, locks it into place, making removal a serious pain by comparison. To get an idea of what you’re dealing with, here is a mirror off the car with the spring/tabs exposed (tabs circled in blue). It is this spring that has to be pushed in towards the mirror so that the tabs on the spring will clear the mounting button, allowing the bracket to slide up and over it.
    You will basically have to insert a small slotted screwdriver into the slot opening at the bottom of the mirror bracket’s base, and gently tap at the screwdriver (preferably with a rubber mallet) till it pushes the tab back far enough to clear the button. The screwdriver is in far enough when it won’t fall back out with little force, but at the same time, not so snug that it takes a lot of force to get it unstuck. Take your time, and check to see if it’s at this point with every few taps. Driving the screwdriver in too far can cause the windshield to crack or break. Here’s an off the car visual to give you an idea of what you’re looking for.
    At this point, the mirror bracket should slide out by gently lifting UP on the mirror while wiggling it back and forth.
    Again, I have to stress to be extremely careful with the removal of these mirrors. The process itself sounds straightforward and easy enough, but the springs are often stubborn, so you have to be very cautious not to exert enough force to break the windshield.
    Tip: If you do not feel comfortable trying to remove the mirror yourself, skip to the wiring so that’s in place, and then take the vehicle to a glass or body shop to pop the mirror off. Most will remove rear view mirrors for $10 - $15, and many will even do it for free! Same with reattaching mirrors that have fallen off!
    Replacing/swapping factory auto-dimming mirrors
    If your vehicle already came with a Donnelly or Gentex, and you're looking to swap mirrors for more features, or because your Donnelly broke, then this will be a fairly easy process, as all the essential wiring will already be there. The first thing you will need to determine is if you have the older style 3-pin harness, or the newer style 7-pin harness, as illustrated below.
    If you have the newer 7-pin style with only 3 wires coming out of it, then this will be a direct plug and play. If it is a 7-pin, but there are more than 3 wires present (i.e. your current mirror has map lights), then you will simply pull out the extra wires from the harness, and either cut them off at a point where you can’t see them anymore, or if you’d prefer to keep them in tact, wrap up the tips to prevent any electrical problems, and tuck them away in the headliner. You can then just plug in your existing harness into the new mirror.
    If you have the older 3-pin harness, this will still be an easy swap, just slightly more time consuming/involved. Without loosing the order the wires are aligned in, remove the pins from the old harness with a small flat screwdriver. Do the same for the wires coming out of the harness on the new/replacement mirror.
    Next, with the new harness facing in the direction it will be in when plugged into the mirror, and the wires from your vehicle aligned in the same order they were in when removed from the old harness, push the wires from your vehicle into the pinouts in the new harness from right to left. A pin-out is provided after the next section.
    Installing auto-dimming mirrors in non-factory equipped vehicles
    If your vehicle came from the factory with a standard mirror, don't worry. An auto-dimming mirror can be installed into ANY vehicle with a very small amount of electrical know-how. All it will require is one wire running to a +12v that powers on with the accessories, and one grounded wire. The self dimming and compass features are self contained and need only that one power wire to function. The 3rd wire automatically disables the self-dimming feature when the vehicle is put into reverse, but most people seldom wire it, as it is an unimportant feature and not worth the trouble. If you have a mirror that shows outside temp, you will need to get a temp sensor as well, and run a wire from the sensor to the mirror. Whether you have a 3-pin, or 7-pin harness, the following is the correct wiring for the majority of auto-dimming mirrors with or without compass when looking at the front of the mirror with the harness plugged in. Obviously ignore the 7th pin if your replacement mirror doesn’t have map lights.
    And that’s all there is to it! If you have any questions I haven’t gone over, please feel free to ask. BTW, I have amassed a rather large collection of fancy mirrors of all types, and will be posting a thread for them in the classifieds section soon. I will provide a link here when I do. All my mirrors are tested prior to sale as well. As a general idea, an auto-dimming Gentex or Donnelly is $55 shipped within the continental US. A Gentex with a compass or Donnelly with map lights is $70 shipped.
    EDIT: Link to mirrors for sale http://www.grandprixforums.net/mirro...ors-78455.html
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  2. #2 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Mine straight up doesnt do anything.
  3. #3 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    Great info thank you!
  4. #4 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Donating User Odi's Avatar
    Chicago South Suburbs
    My favorite armenian genocide survivor writes good stuff
  5. #5 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Dec 2011
    Grand Prairie, Tx
    Mine is burnt out
  6. #6 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Dec 2008
    Naperville, IL
    Quote Originally Posted by jwjones View Post
    Mine is burnt out
    What do you mean by "burnt out"? Is there liquid showing inside of it?
  7. #7 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Illinois
    I know your pain jwjones. mine is goldish yellow on 95% of my mirror except the top then its regualr mirror color.
  8. #8 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Dec 2008
    Naperville, IL
    ....you guys realize the original post is devoted to explaining why that happens, and how to remedy the situation, right?
  9. #9 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Jan 2012
    Abilene, KS
    What color is each wire coming from the factory harness?
  10. #10 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Never Never Land
    Any wiring info on adding a temp mirror on a car that came with a basic mirror? No auto dim or anything. I do have a temp sensor in he front of the car down on the bumper support if that matters
  11. #11 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Bunnell, FL
    you should have the harness in the headliner for the 3 pin
    I'm a Sex Offender
  12. #12 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Never Never Land
    Sawweeetttt. I'll check it out today. Thanks Z3
  13. #13 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Dec 2008
    Naperville, IL
    Are you saying all GPs or GTPs came prewired for the auto-dim mirrors? And even if the 3 pin wire is there, he will need to wire the temp sensor in separately. The 3-pin wires will just cover power to the auto-dim and compass/temp display, the ground, and the disabling auto-dim in reverse feature. He will still need to run a wire from the temp sensor to get an actual temp reading, and I believe a separate negative is also required for that sensor. 4th, the temp sensor you're referring to, is it for the digital dual climate control?
  14. #14 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Kansas
    Damn Rare... I knew you had a thing for mirrors but ****TT!!
    But very informational post man. Probably one of the best I've seen in a while bringing new information to the table.
  15. #15 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Never Never Land
    I dunno. I'm assuming so cause my bro's car has that same sensor and his has dual digital
  16. #16 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    I'm confuse does my 04 gp came prewired for the auto-dim mirror?
  17. #17 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Dec 2008
    Naperville, IL
    I'm not 100% on this, but I don't think any of them came prewired, crazy. There are a few different mirrors available for the w-bodies, and there are at least a couple different harnesses for them, so I don't see how they could be prewired since which harness the car would need is dependent on which mirror option it got.
  18. #18 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    May 2011
    El paso tx
    Check my 04 and it wasn't prewired that sucks
  19. #19 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Dec 2008
    Naperville, IL
    I didn't think so, but honestly, it's very easy to do. Just one wire grounded for your negative, and one wire tapped to a source that comes on with accessories is all it takes to power a self dimming compass mirror. If you want one with outside temp, you'll have to buy a temp sensor to install somewhere around the front bumper and run 2 more wires to the mirror from it. Map lights will be a bit more involved if you don't already have a mirror with them. However, if you don't, it's most likely because you have map lights on the overhead dome, so you don't need a mirror with lights anyway.
  20. #20 Re: Everything you ever wanted to know about auto dimming rear view mirrors
    Aug 2012
    Danville
    I have the 3 pin automatic mirror on my 1999 GTP. The auto dimming feature does not work. I tested it and it is only getting .11 volts to the mirror. Where should I look to fix this? Thanks.
  1. Rear view mirrors
    By SDGTP99 in forum General Tech Discussion
    Last Post: 08-02-2011, 08:46 AM
  2. Side view mirrors and red interior illumination
    By the_pack_rat in forum Visual/Body Modifications
    Last Post: 05-27-2009, 04:39 PM
  3. rear view mirrors grrrr
    By gtpinsc in forum General Tech Discussion
    Last Post: 09-21-2008, 06:50 PM
  4. Rear View
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2008, 03:01 PM
