Thread: How to get PCV to work instead of valve cover breather!
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 122
  1. #81
    Mercer, Pa
    Does the tiny groove LIM and gen 3 Intercooler work with gen 5 supercharger. I no supercharger will work, but does the PCV system work?
  2. #82 Re: How to get PCV to work instead of valve cover breather!
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    How do i find out if its working? Or know for sure?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
    Mercer, Pa
    I'm not sure other than see how the pieces all line up, but you already have it together.
    ZZP made 2 separate manifolds for a reason!
    I would hook the N* to the front valve cover and not use or worry about the tiny groove. Just cap the nipple on back of gen 5.
    Bowie, MD
    Ok ill hook it up to the front valve cover. Would the oil cover be okay also or does it have to actually be the valve cover?
    Sent from my SGH-T989 using Tapatalk 2
    Mercer, Pa
    Valve cover, valve cover cap or the extension tube for the cap.
    Bowie, MD
    Ok cool. Ill try it out I'm the am.
  7. #87 Re: How to get PCV to work instead of valve cover breather!
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    So I am all kinds of confused! I am trying to determine exactly what needs to be done before I get too deep into this upgrade.
    My current setup is a L36 w/ stock top swap. I will be doing a Gen V blower spaw with a Gen III IC (I believe its a stage 2 ZZP unit). I will be using a N* TB and LQ4 MAF. I feel that I can modify my IC to match the PCV holes on the rear.
    That being said, what exactly do I have to do to obtain a properly functioning PCV system? ...My understanding is that I will only have to connect the nipple on the back of the Gen V to the nipple on the N*. Yes?
    02 sedan, top swap
  8. #88 Re: How to get PCV to work instead of valve cover breather!
    Pennsylvania
    If you're going to modify the IC to allow for stock PCV function, then you are correct; connect the stock PCV nipple on the SC to your throttlebody, just like stock. Stockity-stock-stock.
    Bowie, MD
    What i did to make mines work was plug up the rear nipple....the ran a line from the nipple on my N* to the hole i tapped on my valve cover oil cap.
  10. #90 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    For a gen 5 supercharger with n*.
    You need the zzp tiny groove manifold made for the Intercooler or just like in the original post connect front valve cover to the n* throttle body and cap the nipple on the back of gen 5 supercharger.
    The front hole does not line up through the Intercooler that is where the tiny groove manifold comes in. The rear hole can be drilled in manifold.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Or you could always add a breather and disable the PCV.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  12. #92 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    Quote Originally Posted by Sushamouf View Post
    Sent from my Droid
    The Name of this thread is "How to get PCV to work instead of valve cover breather!"
    May 2011
    United States
    My bad, forgot which thread I was in.
    Sent from my Droid
  14. #94 Re: How to get PCV to work instead of valve cover breather!
    Apr 2011
    Vassar, Mi
    Waking this up because I am doing this same crap right now and wanted to add some info. I am putting a Gen V blower on a ZZP intercooler designed for a Gen 3 and using my own modified L67 lower intake. It seems to me that with this setup, even if you have a ZZP lower intake with the tiny groove in it you cant run the front PCV through the intercooler plate and supercharger by using the normal Gen V PCV nipple on the back. Atleast not without some TIG welding, milling and drilling. There is a small section of the PCV passage on the bottom of the Gen V that is exposed to the opening in the intake which would seem to negate all PCV function and even possibly create a uncontrolled idle/internal vacuum leak of metered air. Also the upper hole would have to be redrilled 1/4" over as it is mostly blocked. I will be capping the nipple and venting from my N* to the front valve cover. It seems to be the easiest way.
    The pic is with the plate pushed as far to the edge of the bolt holes as possible, to cover as much as possible, with the plate centered it is worse.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  15. #95 Re: How to get PCV to work instead of valve cover breather!
    Feb 2013
    Detroit, MI
    So I have a question,
    2006 gp gt
    Gen v
    L32 lim
    Do I drill and tape this 1/4 hose barb like Anthony did?
    Where does it go to though? Between the maf and tb? Or to the supercharger?
    I can't tell in his pics. Will this correct the front pcv working properly and not running a breather?
    1/4 hose barb I believe
    Doesn't look to be hooked up here.
    There it is here.
    Can't tell where it goes.
  16. #96 Re: How to get PCV to work instead of valve cover breather!
    Florida
    Yes, that will allow for proper front PCV operation with a breather. It will need to go between the Maf and the throttle body blade. I believe he's using the N* so it would go onto the vacuum port.
    On my build, I'm running a breather, though I plan to switch over to what Anthony, or even just tap the VC. I drilled and tapped the TB and ran a vacuum line from there to the rear PCV on the Gen V
  17. #97 Re: How to get PCV to work instead of valve cover breather!
    Feb 2013
    Detroit, MI
    So something like this needs to be done for the front and rear? Or the zzp already has the rear?
  18. #98 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    Need a little info, I'm confused.
    Isn't a 2006 GP GT already supercharged? It is this top swapped NA?
    Who's intercooler?
    Stock LIM or came from vendor for intercoolers?
    What throttle body?
  19. #99 Re: How to get PCV to work instead of valve cover breather!
    Quote Originally Posted by sseilmnop View Post
    Who's intercooler?
    What throttle body?
    I'll help out
    Yes factory SC GT
    Stock lim.. That he opened up himself
    Wbs store IC which turns out to be a ZZP
    Stock TB
    04 Comp G.
  20. #100 Re: How to get PCV to work instead of valve cover breather!
    Feb 2013
    Detroit, MI
    Who's intercooler?
    What throttle body?
    Yeah it came supercharged, although some 06 gt's don't surprisingly.
    Zzp 2.25 intercooler, stock lim that I modified, stock throttle body.
    My lim, before cleaning it up better.
    My ic
    My tb
  1. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  2. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  3. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
