Thread: How to get PCV to work instead of valve cover breather!
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 122
  1. #61 Re: How to get PCV to work instead of valve cover breather!
    GTX Level Member colindunn's Avatar
    Aurora, IL
    There's already a fitting on 04+ so I block off the nipple on the gen v supercharger and connect a hose from valve cover to intake between maf and plate? And that's it?
    Green Comp G. Headers. Intake. Tune. Pulley. Intercooled.
    SE fascia. Dual chrome tips. Debadge. Retrofit. Lowered.
  2. #62 Re: How to get PCV to work instead of valve cover breather!
    If the PCV is external on the gen V, then that PCV will still have to be hooked up as well as that will provide the PCV for the rear head.
  3. #63 Re: How to get PCV to work instead of valve cover breather!
    Pennsylvania
    Matt, I thought you only had to run a hose from the front valve cover to the intake like sseilmnop said. Could you explain what you suggest instead?
  4. #64 Re: How to get PCV to work instead of valve cover breather!
    Most intercooler cores leave the rear PCV function alone.
    If his PCV leaves the blower from that nipple on the back, it still has to be connected otherwise there will be no PCV for the rear head unless you tapped both valve covers.
    Up to you. I think it'd be cleaner to utilize the existing nipple/system for at least one head.
  5. #65 Re: How to get PCV to work instead of valve cover breather!
    Aurora, IL
    Hose from rear nipple, hose from front valve cover, into T and single hose to intake
  6. #66 Re: How to get PCV to work instead of valve cover breather!
    Pennsylvania
    Okay, so what if the PCV is blocked like in sseilmnop's core? Do you need to tap the rear valve cover as well as the front?
  7. #67 Re: How to get PCV to work instead of valve cover breather!
    Yes, but neils core has rear PCV.
    Mercer, Pa
    Quote Originally Posted by colindunn View Post
    i get it but there are too many combinations of throttle bodies and intercoolers and superchargers so what do i have to do if im intercooling my L32 with a L32 throttle body and Gen V where the pcv already connects in between the throttle plate and MAF?
    Intercooler is not a zzp with tiny groove on LIM. Connect front valve cover to stock l32 throttle body. Block nipple on back of gen 5 super. This nipple use to connect to l32 TB it now will connect to valve cover.
  9. #69 Re: How to get PCV to work instead of valve cover breather!
    Then you don't have any rear PCV?
    Mercer, Pa
    Quote Originally Posted by SlowNA06 View Post
    ZZP WBS and sseilmnop have rear PCV hole. WBS and sseilmnop are same, rear only. ZZP has front groove and requires nothing to get PCV to work.
    WBS and sseilmnop require front valve cover only.
  11. #71 Re: How to get PCV to work instead of valve cover breather!
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Hey sseil i just recently got my hands on a Gen V. My current setup before getting a gen V was a zzp stage 2 intercooler setup with ported gen 3 blower and ported tb. Basically from what ive read.....If i want to replace my gen 3 with my new Gen V and want everything to work correctly,....i should drill a hole and tap my ported L67 Throttle body as you pictured on the first page.....and then run a line from that tapped hole to the nipple on the back of the Gen V? Is that all i have to do? And should i use a L32 supercharger gasket? I was using an l67 supercharger gasket with my gen 3.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
    Mercer, Pa
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Yes, drill and tap throttle body and connect to nipple on back of gen 5. The gen 5 should work with l67 intake. I don't no which gasket / gaskets sorry.
  13. #73 Re: How to get PCV to work instead of valve cover breather!
    went out and looked at mine and as I thought before, the genIII core blocks the genV so putting a vac hose on it does nothing...
    Mercer, Pa
    Quote Originally Posted by gtpsleeper View Post
    If tiny groove and stuff are blocked by l67 LIM / gen 5 combo then connect TB to valve cover breather.
  15. #75 Re: How to get PCV to work instead of valve cover breather!
    Bowie, MD
    ok cool will do thanks again
  16. #76 Re: How to get PCV to work instead of valve cover breather!
    Bowie, MD
    I connected my N* TB nipple to the back of the Gen V and i think i have full pcv function. How can i tell if i dont? I am getting vacuum from the rear nipple on gen v when i tested.
  17. #77 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    Your setup.
    Gen 5 supercharger
    Gen 3 intercooler
    Gen 3 LIM W/ zzp tiny groove for PCV
    North star TB
    You are getting vacuum at the rear nipple on super.
    Im not sure that the tiny groove on gen3 LIM works with gen 5 supercharges. And it is pretty easy to get manifold vacuum leaking by the gasket into the PCV passages which would give you vacuum and boost.
    Bowie, MD
    What do I do about the evaporate? My gen v to N* adapter doesn't have a fitting for it to plug in so I capped it off earlier and then werytime I went to fill up gas would pour out of the gas tank neck and wouldn't allow me to fill up. Can I add a T and tap into the pcv vacuum line?
    Sent from my SGH-T989 using Tapatalk 2
    Quincy, Mass
    I used the stock location on the back of the gen V under the pcv vacuum nipple and used a gen v evap. You'll need to flip your n* adapter upside down to use which doesnt effect anything as long as your coolant holes in the lim are plugged.
    No more GP 04 Impala SS Indy:
  20. #80 Re: How to get PCV to work instead of valve cover breather!
    Bowie, MD
    does the l67 okay cool.
  1. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  2. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  3. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
