Thread: Engine Mount Replacement [*]
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #41 Re: Engine Mount Replacement [*]
    Long Island
    Does someone have a link to the Engine mount replacement How-To? I have tried searching all through the forum and can't find it. If it has been removed would anybody be willing to write up a new one?
  2. #42 Re: Engine Mount Replacement [*]
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Quote Originally Posted by chuckb223 View Post
    http://www.grandprixforums.net/motor...ng-46266.html#
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  3. #43 Re: Engine Mount Replacement [*]
    Jun 2013
    Arizona
    I have an 02 and had similar issues as GeeBee. My tranny mount took about 30 minutes, including r/r of fire. Piece of cake.
    The passenger side was a pain. I had to remove bracket from motor and pull it out with mm. No space to get anything on top nuts. Removal of bracket was hard because I could only use a 15m off set wrench and only turn about 100 degrees at most each turn. Often less.
    Had a hard time getting front bracket bolt reinstalled. Just couldn't get bolt through bracket and threaded into motor. Finally was able to pry mount and bracket over with a long screwdriver so that the hole and bracket would align. Also a tight space so it was hard to get my hand in there to start bolt. It also didn't help to have the oily, greasy stuff on every surface, even after I did a lot of clean up. Whole thing took about 4 hours but 2.5 of that was messing with the one bolt. Didn't see GeeBee's post prior. My mounts and tray looked just like Sykkel's pictures. Tranny mount was clean but hard and cracked.
  1. Spacing lower engine motor mount...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2012, 03:51 PM
  2. Could it be an engine or tranny mount?
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2010, 11:12 PM
  3. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
