Thread: Tip: Sunroof issue fix 04+
Results 1 to 5 of 5
  1. #1 Tip: Sunroof issue fix 04+
    Omaha, NE
    I've been having trouble with my sunroof for quite some time now. My issue was that it seemed to be getting stuck after going a short distance on the tracks. I went to the parts store inside my local "pontiac" dealer and the parts guy said its probably a $250 or so sensor that says when its open all the way.
    Tonight I bought some small magnets (stong little round ones) for my license plate (that's a whole other story) and I was waiting to meet someone so I started to play with the magnets. I ran it over the dome light housing just to the top right of the crack separating the two lights (you should be able to feel the magnets pull a little bit). If it doesn't work right away, keep trying. It worked great for me.
  2. #2 Re: Tip: Sunroof issue fix 04+
    May 2008
    Winnipeg, MB
    were you holding the button to move the sunroof open while moving the magnets around?
    2007 Pontiac Grand Prix
  3. #3 Re: Tip: Sunroof issue fix 04+
    Grand Island, Nebraska
    Brotip: use magnets
  4. #4 Re: Tip: Sunroof issue fix 04+
    Omaha, NE
    I was just moving the magnet around until I found that spot. I didn't hit it right away becasue my problem only got slightly better at first. I then opened it while using the magnets and it opened completely in the first try. I removed the magnet and it functions now as it did when I bought the car.
  5. #5 Re: Tip: Sunroof issue fix 04+
    SE Level Member nyydmb12's Avatar
    New York
    Hey did your sunroof start doing this after you noticed some water leaking from there. That is what happened to me ... I guess it couldn't hurt to play with some magnets though thanks for the info.
    2004 grand prix gtp
  1. Sunroof
    By SuperCharged0nE in forum Visual/Body Modifications
    Last Post: 11-22-2009, 09:59 PM
  2. Sunroof
    By 1LoudGrandPrix in forum Visual/Body Modifications
    Last Post: 10-11-2009, 07:37 AM
  3. Sunroof
    By K1J1E2 in forum General Tech Discussion
    Last Post: 03-12-2009, 11:43 PM
  4. Help with sunroof!
    By kbwent in forum General Tech Discussion
    Last Post: 02-22-2009, 08:55 AM
  5. HELP! Sunroof
    By GTPluv in forum General Tech Discussion
    Last Post: 10-19-2008, 07:04 PM
