Thread: Strut removal and installation
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Strut removal and installation
    Grand Rapids, MI
    k guys i put new KYB Strut-Plus assemblies on the GP last night, new wires, and a front valve cover gasket
    It made a WORLD of difference with the ride quality (can't wait to do the back ones)
    The only problem I have is that the steering wheel is cocked way to the left (instead of the right where it was lol) and it tends to drift both left and right kinda like I have to work to keep it in a straight line. Also on uneven road it still tends to act up and steer all over the place.
    I'm assuming all of that is due to needing an alignment... hopefully that fixes it?
    For the most part I am really impressed. The handling is improved despite the straight line issue; It no longer feels floppy all the time.
  2. #22 Re: Strut removal and installation
    Charles City, IA
    Yeah get an alignment and it should fix it.
    SMGPFC Two Nipple General
  3. #23 Re: Strut removal and installation
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i did all four struts and had to do an alignment but before u do defintely check your tie rods and wheel bearings make sure there in good shape as well
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  4. #24 Re: Strut removal and installation
    Y u no reinstall rear strut caps?
  5. #25 Re: Strut removal and installation
    Sep 2011
    WV
    So im going to assume that this process would be the same for a 2004 ?
  6. #26 Re: Strut removal and installation
    yeah, pretty darn close to the same.
  7. #27 Re: Strut removal and installation
    Jun 2012
    St. Paul, Minnesota
    Excellent write up. Everything went as expected.
  8. #28 Re: Strut removal and installation
    SE Level Member fmayo's Avatar
    massachusetts
    I finally got it all done but have a problem. Driver side front strut makes "popping" noise intermittantly. Did I screw up when I compressed the spring and installed the strut mount? I thought maybe something just loosened up, but rechecked all the bolts and they are tight. But the top cap of the strut assembly (in the engine compartment) actually can spin, so I know there is no pressure on it. Can anyone tell me where I went wrong?
  1. Airbag removal and installation
    By mach158 in forum General Tech Discussion
    Last Post: 06-05-2011, 05:07 PM
  2. HId Installation??
    By silvermistgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2009, 08:29 PM
  3. HUD Installation- HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 10-08-2009, 08:03 PM
  4. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
  5. Steering Wheel Removal & Installation
    By $03gp/gt$ in forum General Tech Discussion
    Last Post: 12-14-2008, 07:38 PM
