Thread: Intermittent Power Door Lock
Results 1 to 4 of 4
  1. #1 Intermittent Power Door Lock
    SE Level Member jejensen's Avatar
    Iowa
    My 99 GP passenger side power door lock failed to lock intermittently. It would always unlock but would sometimes not lock. The drivers door always worked ok. The BCM (Body Control Module) controls this function so I tested the door lock circuit at the connector (C1 - pins A, B, C) on the BCM. I could get the door to lock/unlock correctly when applying power to the appropriate pins.
    +12V to pin C, GND to pin B will lock the passenger door; GND to pin C, +12V to pin B will unlock that door.
    +12V to pin C, GND to pin A will lock the drivers door; GND to pin C, +12V to pin A will unlock that door.
    Since that test proved the door lock motor and wiring to that motor must be ok, I went inside the BCM. The locking circuit is controlled with 3 relays inside the BCM. I replaced all three of these relays even though only one of them was bad. The relays originally used were Siemens brand. I could not find them so found an alternate that had the same pin pattern and ratings. It was an Omron G5LE-14-DC12 and can be purchased from Allied Electronics for $1.06 each. I desoldered the old relays, soldered in the new relays and my passenger side power door lock has worked ever since.
  2. #2 Re: Intermittent Power Door Lock
    Thanks for a legitimate tech tip.
  3. #3 Re: Intermittent Power Door Lock
    Charles City, IA
    Good tip, but I would just get a bcm, far to lazy for soldering in relays.
    SMGPFC Two Nipple General
  4. #4 Re: Intermittent Power Door Lock
    Iowa
    Yeah, I considered the same but even getting a used on on eBay plus taking it to a dealer for programming would have cost over $150 so just bought the relays for under $5 and did the repair myself. It only took around 30 minutes and really wasn't that hard as long as you have a good desoldering iron
  1. Driver's door power lock issue.. :(
    By daiadvisor2 in forum General Tech Discussion
    Last Post: 09-05-2010, 08:13 PM
  2. Intermittent Power Window Issues
    By davetach in forum General Tech Discussion
    Last Post: 08-22-2010, 12:12 PM
  3. Door lock help
    By toolguy in forum General Tech Discussion
    Last Post: 09-11-2009, 08:23 AM
  4. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
  5. Power Door Lock Problem-O
    By flynn in forum General Tech Discussion
    Last Post: 12-31-2007, 04:49 PM
