Thread: General Info: Swap your steel oil pan for an aluminum one
Page 4 of 4 FirstFirst ... 234
Results 61 to 69 of 69
  1. #61 Re: General Info: Swap your steel oil pan for an aluminum one
    Buffalo
    Chats
    7841
    Yeah cause you know , I do things half ass
    let me know when you find a gasket
  2. #62 Re: General Info: Swap your steel oil pan for an aluminum one
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    Chats
    LOL nice regal by the way. I have a old gasket just no tray I'm not going to be able to find that without buying a whole new aluminum pan.
    Most all series 3 motors( iv a few series 2 motors came with the aluminum pan) from u pull yards have the series 3 motors pulled already. So that wouldn't help to much.
  3. #63 Re: General Info: Swap your steel oil pan for an aluminum one
    Buffalo
    Chats
    7841
    Thanks !
    When I opened up the 06 l26 there was no gasket. Just grey rtv
  4. #64 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    Chats
    Yeah I know that's how there suppose to come from the factory. But the motor i pulled the aluminum pan from was modded and that's how I found it with a old style gasket and tray gone, that's what confused me.. I know it ran so it should be fine with a gasket ya know...
    'm tired of working on cars...
  5. #65 Re: General Info: Swap your steel oil pan for an aluminum one
    hangover park IL
    Chats
    910
    the plastic gasket/windage tray is better than the oem steel tray in the alum pan, if you don't use the built in mount then you can use the plastic gasket. if your using the pan mount and not the horseshoe you must use rtv.
    its why I still prefer the steel pans.
    well that and having seen two of em die since the alum pans shatter with debris than get dented....kinda hard to hold oil in the sump when the pan is brittle.
    ~James~ Psychotic Gearhead
  6. #66 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    Chats
    Ok Gotcha thanks
  7. #67 Re: General Info: Swap your steel oil pan for an aluminum one
    Chats
    243824
    if you put a gasket in there, make sure to rtv both sides of the gasket, the engine i got used had a new gasket on the pan and it was leaking. i put another new one in but with rtv on both sides and no leaks.
  8. #68 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2012
    Chicago
    Chats
    Right... Rtv between the plastic gasket and aluminum pan surfaces. OK I think that's what Turbo meant as well...
  9. #69 Re: General Info: Swap your steel oil pan for an aluminum one
    Aug 2018
    PA
    Chats
    118
    Hey guys I have read alot about this but still am unsure of exactly what I need to do the swap for my 99 grand prix. part numbers would be most helpful. Thanks in advanced.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2022, 02:44 PM
  2. Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    By LowlyfeGTP in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:14 AM
  3. Top swap and general question
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2010, 08:28 PM
  4. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
  5. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
