Thread: L67 motor swap (with video)
Results 1 to 20 of 27
  1. #1 L67 motor swap (with video)
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Things needed:
    7mm
    8mm
    10mm
    13mm
    15mm
    18mm
    19mm
    Flathead screwdriver
    Fuel line seperator
    a few 5" extensions to spare
    Cherry picker
    Pry bar
    L67 (obviously)
    1. Alright, where to start haha. First things first, removing the harness. Injectors you simply push the clip in and pull up. everything else (ie. maf, iat, fans, egr, evap, etc.) are just pull up style clips. Make sure to get them all. Knock sensor, speed sensor, both o2 sensors are all located in the passenger wheel well. Also while you're at it. Be sure to get the vacuum lines and fuel lines
    2. Next is the mounts and what not. Dog bones are 13mm, dog bone brackets, motor mount is two 15mm. If you have an STB, that's 4x 13mm bolts to remove
    3. Disconnect the throttle cables and intake piping. Go around to the passenger side and seperate the power steering pump (2x 13mm's) and a/c compressor (5x 15mm's) from the block.
    4. While you're on the driverside go ahead and remove the 4 18mm bolts holding the trans to the motor. Once done, go around to the passenger side with a few extensions and through the wheel well start feeding them through to get the last trans bolt just under the rear exhaust manifold.
    5. Almost ready to be pulled. Go ahead and hop under the car to do that last few things. DP is two 13mm's. Can be a pain to get to even with extensions. Next, the tq converter/flex plate bolts. They can be a bit difficult as the motor will turn with any bit of pulling to the left or right. there's two ways to go about this. You can either have someone stand up top with a 24mm and a breaker bar on the crankshaft bolt to keep it from spinning, or you can wedge a screwdriver in between the starter and flexplate teeth
    6. Motor is ready to be pulled. Simply attach the engine hoist to the two support brackets. One is located on the passenger rear just beside the firewall and the other on the driverside front next to the driverside fan.
    7. Before pulling, with a big screwdriver or some sort of prying tool, seperate the trans from the motor.. Make sure to leave it wedged as you're going to need to keep the flexplate clear from the trans bellhousing when pulling.
    8. Once the motor is out you're going to need to grab a few things off of it before you continue. First is the MAP sensor. Located on the left side on the upper intake manifold/plenum on top of the PCV. Be careful when removing as it can seperate into two pieces.
    9. Next thing is the flexplate. The L67 uses a larger torque converter (258mm instead of the L36's 245mm) so the bolt holes will not line up. There's 10 15mm bolts if I recall holding this in place.
    10. Lastly is the simplest, the plastic fuel line connectors on the fuel rail. L67 uses a 4 point metal connector while the L36 only has two point plastic ones Should just come off by prying a screwdriver between them and the fuel rail ends.
    11. Once the L36 flexplate is attatched, the L67 is ready to go in...
    12. Drop the motor in slowly making sure to not catch any of the harness or fuel/vacuum lines.Can be tough trying to line the motor up to the trans while trying to get the two motor mount bolts in the holes.
    13. repeat the previous steps 5 and up backward to finish up
    14. Once you get to the fuel rail remember to attach the plastic connectors so you can use the stock fuel lines.
    15. Next is the MAP sensor. Normally the L67 MAP sensor mounts in the back and also has a different connector. The simple solution is to just take the line leading to the BBV solenoid and plug it into the L36 MAP sensor.
    16. While talking about the BBV solenoid, just unhook the vacuum line leading from the actual solenoid to the sensor and throw the sensor away. I've done this to both my GTP and SE and no codes are poped and also runs just the same.
    18. You're done! add fluid and hopefully it starts.
    Also, just for a little visual, here are some pics as well as video updates from when I did this.
    YouTube - L67 Swapped 2000 SE [Pt.1]
    YouTube - L67 Swapped 2000 SE [Pt.2]
    YouTube - L67 Swapped 2000 SE [Pt.4]
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  2. #2 Re: L67 motor swap (with video)
    SE Level Member Boostd1's Avatar
    Thornton, Colorado
    Wow haha you weren't kidding about your boredom! Nice job though Remember kiddies, L32 is the same exact instructions. Just swap out coolant sensors
    Oh and also, try not to shoot yourself in the face while attempting step #4, cause you WILL be tempted to...
    "The only sustainable competitive advantage is the ability to learn faster than the competition."
  3. #3 Re: L67 motor swap (with video)
    Kansas
    You make it look to easy
    SOLD 1999 GT Silvermist TS
  4. #4 Re: L67 motor swap (with video)
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    Quote Originally Posted by Gafford44 View Post
    x2 - Good job
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  5. #5 Re: L67 motor swap (with video)
    GTP Level Member SuperSport's Avatar
    Michigan
    Wow I just watched all the videos including the startup video. This seems easier than a top swap. Did you swap the PCM too?
    I want to do this to my GT...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  6. #6 Re: L67 motor swap (with video)
    Thornton, Colorado
    This is great info kiddies. Go ahead, do a motor swap. There fun! In this case I swapped out my 140K miles L36 top swap for a 26k miles L32.
  7. #7 Re: L67 motor swap (with video)
    Nov 2008
    Still rolling on the original SE PCM. You see the man above this post.. He tuned my PCM using GTP tables haha.
  8. #8 Re: L67 motor swap (with video)
    Nice write up. Would you please fix the trans to engine bolts to be 18mm's. And the AC compressor is only 3 15mm's. No need to remove the bracket before it's out.
    I do the fuel lines before hooking up the hoist, along with a few other things like supporting the trans. ...but it's a great overall writeup.
  9. #9 Re: L67 motor swap (with video)
    Michigan
    Quote Originally Posted by ninnyGTP View Post
    Hmm too bad nobody lives close to me to tune my pcm.
  10. #10 Re: L67 motor swap (with video)
    Nov 2008
    haha yeah, that rear trans bolt hd me stuck easily for about 45 minutes. Mainly because you can't get any real leverage on it due to all the extensions without it slipping off
  11. #11 Re: L67 motor swap (with video)
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    This seems easier than a top swap. Good write up sir
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  12. #12 Re: L67 motor swap (with video)
    Nov 2008
    Depends on how you look at it. They both have their tough areas. Either or, you're going to be happy. I just think the whole motor is the more reliable route even if you lose the higher compression advantage of the L36 bottom end
  13. #13 Re: L67 motor swap (with video)
    Reading, PA
    Ya it seems like mote could go wrong with a top swap
  14. #14 Re: L67 motor swap (with video)
    Banned - Busted For Scamming
    Feb 2009
    Yup
  15. #15 Re: L67 motor swap (with video)
    Apr 2009
    stockton ca
    I hoping to do my install in 2 class days so around 6 hours but theres the issue of the bolts tray we knocked over on removal so that should be fun figuring out what wnet where
    I left the B!tch bolt out when i did the trans swap At school its so much easier though with a lift and a few 3 foot extensions and a impact
    We watched a group take 3 days around 10 hours to pull a 350 out of a 92 chevy that was just sad
    Good write up though Ill be printing it out for install time
  16. #16 Re: L67 motor swap (with video)
    Donating User Odi's Avatar
    Chicago South Suburbs
    If only I had the money for the tranny and the engine... I want myself a swap. But im too poor (and would probably take forever on it). Oh well, maybe some other time.
  17. #17 Re: L67 motor swap (with video)
    Nov 2008
    Engine set me back $500 so not too bad considering the miles and year
  18. #18 Re: L67 motor swap (with video)
    SE Level Member Sameyeam's Avatar
    Jun 2010
    how do you get at that rear trans bolt under the exhaust manifold? ive got a long extension but idk how im gonna get it in there, and is there a mount on the passenger side under the motor? thanks great write up ive followed to a "T" up till now im stuck
    00 GT, ams lube and filter, funeral for stock motor on 5/27/10, replaced with 98 L36 with new lim gaskets this time
  19. #19 Re: L67 motor swap (with video)
    GT Level Member mvp2765's Avatar
    Chicago
    good info, i'm looking to pull my engine and these instructions are a start..thanks
    00 Black GTP Coupe - SOLD
    04 Black 350Z touring -currently modding
  20. #20 Re: L67 motor swap (with video)
    GTP Level Member AjL227's Avatar
    IL
    Bump for very helpful instructions.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  1. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
  2. NEED HELP: motor swap
    By fst in forum Northeast
    Last Post: 08-27-2009, 08:50 AM
  3. Motor swap
    By redgp89 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 01:00 AM
  4. Motor Swap
    By Dohner in forum General Tech Discussion
    Last Post: 08-07-2008, 10:59 AM
  5. Land Rover Motor Swap (Video)
    Last Post: 03-19-2008, 08:44 AM
