Thread: Audi style LED lights.
Results 1 to 20 of 40
  1. #1 Audi style LED lights.
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Okay, I was inspired to do this writeup from the guy over there with the white GXP, so kudos to him.
    This is for 04+ only.
    Anyways I would just like to do this because I think it is a really clean look (opinion, no flaming please) and I know some other people on the forum wanted to do this.
    Okay so first off, materials:
    1. Get these from your local Autozone ONLY! (I checked other places, no luck) Pilot Automotive/12 Volts 18 in. white phantom LED interior and exterior strip (CZ-3009W) | LED Light Bar | AutoZone.com
    2. Wire taps (Radioshack or Autozone)
    3. Razor blade
    4. Wire strippers
    5. Masking or electrical tape
    Step 1: Take your headlight off via one bolt on top. Lift the bracket up and pull the headlight out.
    Step 2: Open up your Phantom 18" lights pull the leads of the battery and cut the power and ground cables off. Strip these two wires and inch or so in. This is the box:
    Step 3: This is the part your going to want to be careful with. I wired these up to my parking lights so they can come on with a switch. The only thing I wish is that they came on with an unlock, but whatever. Okay, rather than stripping an entire section off of the parking light, you want to cut two small ovals about 1/4" long each, just barely showing the copper wiring.
    ^Parking light
    Step 4: Slide the parking light ground wire into a wire tap with the metal thing adjacent to the "oval." Then slide in the other wire and crimp the two together with needle nose pliers. One thing I would suggest is doubling up the LED's ground and power wires because they are REALLY thin and will most likely fall out of the tap if they are not doubled up.
    Do this same exact process for power.
    (Bad pic, sorry)
    Step 5: With everything connected turn on the parking lights and test to see that the LED's turn on.
    Step 6: Put your headlight temporarily back in (don't bolt it back in, just use the bracket to line it up to its original position) With the headlight back in, mark the front of the headlight with tape at the bottom (part touching the front bumper)
    Step 7: Take the headlight back off and lay down the LED strip with the included double sided tape (make sure the surface is clean)
    Step 8: Put the headlight back on and enjoy your unique look
    End results with 6k HIDs and Red/White Switchback LEDs (keep in mind this is GXP.)
    With foglights:
    Enjoy and good luck guys.
  2. #2 Re: Audi style LED lights.
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    not bad
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: Audi style LED lights.
    Windsor (ON) Canada
    I have/had something similar set up on my 01. (iphone really eff's up how it really looks)
    May just go and hook them back up.
    Your's looks really clean.
  4. #4 Re: Audi style LED lights.
    Willoughby, Ohio
    Quote Originally Posted by Colossus View Post
    i have the same lights under my projectors, i get compliments all the time on them too, bye bye dim LED halos
  5. #5 Re: Audi style LED lights.
    Jun 2010
    MN
    I have a 02, how did you hook them up and what lights did u use?
    Do u have a write up
    That if you confess with your mouth, "Jesus is Lord," and believe in your heart that God raised him from the dead, you will be saved. - Romans 10:9
  6. #6 Re: Audi style LED lights.
    Quote Originally Posted by alwtkns View Post
    you're sorta kinda just a wee bit posting in the write up thread.
  7. #7 Re: Audi style LED lights.
    looks sweet! I was thinking on doing this to my 97 sometime... Maybe over the winter or next spring .
    Snorlax strikes again.
  8. #8 Re: Audi style LED lights.
    Those are the worst connectors known to mankind.
  9. #9 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Yeah, **** kept falling out. Annoying as hell.
    And thanks for all the compliments guys, hope this helps
  10. #10 Re: Audi style LED lights.
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    Run and tap connectors??? Ewwy
    <MiZzBeCcA>its not rape if you yell suprise
  11. #11 Re: Audi style LED lights.
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Looks pretty clean, and a lot better than some other attempts I've seen, I might have to try this on my GT. Also, believe it or not before this thread I'd never heard of switchback LEDs. Needless to say I've already placed my order for them haha I absolutely HATE how the lights are amber as I'm driving.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  12. #12 Re: Audi style LED lights.
    MO
    get a bumper level view. then i'll put my opinion in
    <brandonl2000> LMAO D!!
  13. #13 Re: Audi style LED lights.
    SE Level Member lcuthber's Avatar
    Feb 2010
    Kokomo, IN
    looks awesome man! I'm assuming that the guy with the white GXP that you referenced was myself! haha. great job on them, they look great.
  14. #14 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Certainly is my friend and thank ya
  15. #15 Re: Audi style LED lights.
    Nov 2009
    South Boston, MA
    It looks awesome man.... so are they inside the headlight?
  16. #16 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Quote Originally Posted by 05PontiacGP View Post
    Nope you just tape them to the bumper directly below the headlight.
  17. #17 Re: Audi style LED lights.
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    looks good but you messed up using those scotch locks your gonna regret that in a year or so
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  18. #18 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Quote Originally Posted by Biohazed View Post
    So I've been told...
    What do you recommend for a fix?
  19. #19 Re: Audi style LED lights.
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    Quote Originally Posted by Koniig View Post
    soldering. thats how i did mine
    pics for those who havent seen
    http://www.grandprixforums.net/revie...com-37233.html
    andsome other pics:
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  20. #20 Re: Audi style LED lights.
    Jun 2010
    Illinois.
    Quote Originally Posted by iroc2 View Post
    andsome other pics:
    I took mine off a few days ago. A few of them went out and I got pulled over for my switchback turn signals and so orange turn signals just weren't matching with the strips lol.
  1. GTP vs. Audi S4
    By Will5600 in forum Off Topic Discussion
    Last Post: 09-16-2009, 07:55 AM
  2. Lights inside an F1 style hood?
    By FuglyGTP in forum Visual/Body Modifications
    Last Post: 03-14-2009, 03:16 PM
  3. VS Audi TT 3.2 AWD
    By 02CL-TypeS in forum Track Sessions and Kills
    Last Post: 08-03-2008, 06:36 PM
  4. run in with a 2005+ Audi A8L W12
    By fst in forum Track Sessions and Kills
    Last Post: 05-06-2008, 09:00 PM
  5. Audi R8
    By GorillaThumbz in forum Off Topic Discussion
    Last Post: 02-10-2008, 11:12 AM
