Thread: 04+ GP Radio Light Fix
Results 1 to 20 of 40
  1. #1 04+ GP Radio Light Fix
    In case your radio lights went out on your 04+ grand prix, here is a write up on how to replace the burnt out bulbs. This is all thanks to 'drmurdoc'.
    Steps for fixing the burnt out display light bulbs on a 2005 Pontiac Grand Prix GT stock radio
    Remove the ring around the ignition. There is a small notch under it. Place a screwdriver there and pry up.
    Pry out the plastic faceplate surrounding the entire center area of the dash. Note that there are no screws. I used a screw driver shown below and just pulled.
    There is wiring attached to the back of this piece. Squeeze the connector.
    Now remove the radio. To do this you have to remove the 2 screws from the storage bin on the bottom, next remove the 2 screws from the climate control and finally the 4 screws holding the radio in. The plastic faceplate on each overlap and the radio is on the bottom.
    The radio has three connections on the back. One is the antenna, pull that out. The other two are wire connectors. Squeeze and pull on each.
    Now take the top (or bottom, not sure which it was, compare yours to the picture) of the radio off. There are no screws that hold it in, you simply pry it off. You need to do this so you can unplug two cables.
    Remove the two cables by pulling them straight up.
    The face plate is held on by two screws on each side along with two pry tabs on the top and bottom. Remove the screws and pry up on the tabs to slide the faceplate forward.
    Now remove the circuit board from the plastic faceplate. There are 5 chrome colored small hex head screws (that I bet you won’t have a driver for). I used needle nose pliers to remove them.
    You now have to remove the display itself.
    The metal bracket around the display holds it to the circuit board by six tabs that pass through the circuit board and are bent. Take your pliers and straighten each one so that you can slide them back through the board. You have to wiggle it a bit and keep straightening the ones that are binding. Not too difficult.
    You will now see the 3 burnt out light bulbs. Note they each have a small plastic covering on them. Slide these off. You will reuse them. They make it so you don’t see the light bulb elements burning through the display. I have removed one in the picture.
    I bought my replacement lamps at the local Radio Shack store for $2.50 each. Note my local store is not a normal one and I don’t think these are standard stock. They say 12V 70mA. However, RS does sell what you see in the second picture and I am sure these would work just fine (catalog number 272-1141). Note both of these lamps have wires vs the solid wire that is on what is installed in the radio. Solid wire lights would be easier to install, but I wanted to get them installed now and did not want to wait for an order of solid wire bulbs.
    Now you have to unsolder each light. I used a pencil soldering iron. I propped the board up vertically between two paperback books. I then touch the iron to each connection and pulled on the bulb (touch one side and pull, then the other, back and fourth).You have to keep doing this side to side until it pops out. Once you have each bulb removed, the holes will be covered up with solder. What I did to open the holes up was touch the iron on the hole and push a small safety pin through the hole and kept moving and twisting it. I was then able to remove the safety pin and have a hole.
    I then took a small X-ACTOknife(a razor blade would work) and carefully trimmed back part of the black plastic covering on each new light bulb. Be careful not to get too close to the leads. The bottom bulb is the trimmed one.
    I then carefully cut back the wire leads to a very short length on each bulb and stripped off a bit of plastic covering on each wire. This task is a bit difficult due to the short lengths. You want to be careful not to pull the wire out of the bulb. Oddly the first one I did was my best (you see it below). I struggled on the two after this one. I recommend buying four bulbs in case you screw up.
    I then twisted the ends of each wire and put them through the holes in the circuit board. This step is also a bit tricky. The holes are not much wider then the wires. I bent the wires down and soldered into place.
    Repeat for the other two bulbs. Now install the bulb coverings. Once you have the circuit board assembled I plugged it intothe radio and took it as is and plugged it into the connectors in the car to test it. It worked! Now reassemble and install.
    Tips
    1. Buy at least one extra bulb
    2. Find bulbs that have solid wires coming out of them vs the kinds I purchased, would have made it much easier
    3. Take your time, took me a good 2 hours.
    4. When removing the old bulbs, you may want to cut their leads if they are quite long and protrude from the board. Mine were. Cutting them first made it easier to unsolder them.
    5. To put the bulb coverings on I put a bit of saliva inside them and they slid right on (Yes I could have easily described these “bulb coverings” in different way throughout this document, however I rose above it…)
    Best of luck.
  2. #2 Re: 04+ GP Radio Light Fix
    pictures will be added shortly, they need to be uploaded to a host first.
  3. #3 Re: 04+ GP Radio Light Fix
  4. #4 Re: 04+ GP Radio Light Fix
    Aug 2008
    KCMO
    ive been waiting for something like this to come along. now i just need someone to find bulbs for the climate control cuz i have had no luck what so ever
  5. #5 Re: 04+ GP Radio Light Fix
    SE Level Member gpgtstan's Avatar
    new brunswick canada
    hey bud thanks alot for this very detailed pics and it worked like a charm thanx again
  6. #6 Re: 04+ GP Radio Light Fix
    Destroys cars izup69's Avatar
    Iowa
    hey thanx havent ben on in a long time was going to install a aftermarket stereo in my car just didnt know how to get the dam thing out plus its a pain to find a wiring harness for the stupid cars that is decently cheap (cheapest i found was at walmart and it was still 40 bucks) now i can finaly hook up my good stereo with my new subs
  7. #7 Re: 04+ GP Radio Light Fix
    Maryland
    Great write up; thanks!
  8. #8 Re: 04+ GP Radio Light Fix
    CATAWBA, NC
    Thanks for all the detail. Does anyone know where to get the bulbs for the rest of the radio (the ones that you see in the pictures that look red)? I have several I need to replace. Thanks
  9. #9 Re: 04+ GP Radio Light Fix
  10. #10 Re: 04+ GP Radio Light Fix
    CATAWBA, NC
    There are probably a million different LEDs available. Does anyone know the specs? Thanks
  11. #11 Re: 04+ GP Radio Light Fix
  12. #12 Re: 04+ GP Radio Light Fix
    Boston, MA
    Hey Bio248 do you think this would work on an 02 GTP? Or does it just work on the newer models.
  13. #13 Re: 04+ GP Radio Light Fix
    Quote Originally Posted by black cherry 40th View Post
    no clue, i would just replace the head unit with a better one.
  14. #14 Re: 04+ GP Radio Light Fix
    CATAWBA, NC
    No way. I like the factory head unit. Well if anyone else might know which LED to use please let me know. Thanks
  15. #15 Re: 04+ GP Radio Light Fix
    davison, michigan
    I just replaced 9 lights on my 97. I basically used the same process as described here, but I found some lights at Radio Shack with the stiff short wires. The cost was $1.7 each. It turned out fine.
  16. #16 Re: 04+ GP Radio Light Fix
    Nov 2010
    Georgia
    Thanks Bio248!! I've been dealing with a radio with no backlight at night for years, and was nervous about resolving this issue. However, now I feel pretty confident!! Bio248, you ROCK.
  17. #17 Re: 04+ GP Radio Light Fix
    Feb 2010
    Nebraska
    for the red light I found a lot of it could you please tell me what size would fit
    found one on ebay T10 W5W RED LED Lamp does it fit to the red one?
    6x T10 W5W RED LED Lamp Car Auto Wedge Sidelight Bulb - eBay (item 130430949411 end time Mar-11-11 01:16:08 PST)
    here is the page on ebay please tell me if that will fit or not
  18. #18 Re: 04+ GP Radio Light Fix
    Quincy, Mass
    No more GP 04 Impala SS Indy:
  19. #19 Re: 04+ GP Radio Light Fix
    Feb 2010
    Nebraska
    ohhh I got that but who did you do it?
    the same as the one it was explained?
  20. #20 Re: 04+ GP Radio Light Fix
    SWPA
    Gonna have a friend of mine do this for me tomorrow. I'm replacing the trans fluid and filter in his wife's car, so he's gonna fix my radio since he has a good soldering pencil and solder sucker. Also helps he's an EE student.
    I'm gonna pick up a few different style bulbs. If I find one that works easily I will be sure to post the p/n.
  1. Radio light is out, how do I fix
    By todd135 in forum Audio, Security & Visual Electronics
    Last Post: 07-26-2010, 07:54 AM
  2. 04 grand prix radio light trouble
    By sasquatch094 in forum General Tech Discussion
    Last Post: 05-20-2010, 05:55 PM
  3. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  4. Light bulb in radio display question
    By singularity in forum General Tech Discussion
    Last Post: 08-31-2009, 09:30 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
