Didn't know where to put the Aeroforce gauge in my 2001 gtp since the pillar pod was full and didn't want to remove any gauges for the ugly Aeroforce that I have so
I moved the heads up display switch to the other side of the steering wheel in the cubby hole. the wiring harness had to be extended for it to reach but the fit was perfect.
next I went and bought a piece of tin larger then the hole in the dash cut a hole in the tin for the Aeroforce to fit, Painted the tin piece and placed it onto the dash trim
little bit of hot glue to make sure she stays in place.
I have no problem seeing the gauge when i want to see it. Just wanted to share
