OK guys here you go an easy fix for you if your fan blower motor squeaks,
First all you need is WD40
Then open the passenger door and look at the bottom of the dash.
Take the push pins out and the bottom cover comes down.
look at the bottom of the blower you will see a small hole in the middle spray the WD40 in the hole and the squeaking should stop.
