Remove your annoying notifications for that stupid thread you shouldn't have posted in three months ago that keeps getting resurrected.
- Point your browser to http://www.grandprixforums.net/
- Log in
- Click User CP, located in the top left corner on the menu bar
- Scroll down to Subscribed Threads, listed in the bar on the left
- Click List Subscriptions
- Click Checkboxes to delete subscriptions, options as follows:
- A. Pick and choose, checking the boxes on the right, then selecting Delete from the drop down menu below and clicking Go
- B. Check the box in the top right corner to select all, then selecting Delete from the drop down menu below and clicking Go
- C. Select Empty Current Folder under the drop down menu at the top to clear all subscriptions.
If you want to keep a couple subscriptions long-term, I suggest perhaps making a new folder to move them to so you can just clear the entire Subscriptions folder when it fills up. To do this, select Edit Folders right next to Empty Current Folder, and type in a folder name in the second box down.
If you want to cease future email notifications:
- Scroll down to Settings & Options
- Click Edit Options
- Scroll down to Miscellaneous Options
- Scroll to Reminder Notification Method
- Use the drop down menu to select notification method, select Private Message
