Thread: 04+ Rack and Pinion replacement [*]
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 66
  1. #1 04+ Rack and Pinion replacement [*]
    I live here. UR LOSN's Avatar
    Rockford, IL
    This writeup on Replacing the Rack and Pinion on 04+ has been added to the How To section and can be found HERE.
  2. #2 Re: 04+ Rack and Pinion replacement
    Oklahoma
    And I was so hoping to see some pictures of you covered in power steering fluid.
    Great work bud. This definitely needs to make its way into the How To section. Would it be safe to assume that its best to have the steering wheel locked into position? Also, would this be a good time to replace that intermediate shaft, or should that be left alone unless its actually bad?
  3. #3 Re: 04+ Rack and Pinion replacement
    Rockford, IL
    well the 04+ the shaft was known to have worn in a bit. Gm had a "quick fix" a squeeze bottle of grease.... we had done this to FastKatts car a few months ago...fixed it for a little while..but it came back.
    the steering wheel can be locked...it only slides on the rack one way. as there is a flat spot.
    it would be a good time to replace it as all you would have to do is pull back the cover under the steering column from the inside of the car, and remove the nut(first), and then slide out the locking bolt. the bolt does NOT turn...only the nut.
    then the shaft just slides out.
    for some odd reason, I didnt get that dirty(just hands). Billy ended up taking the passenger side(he has a leaking CV boot). needless to say, he got quite dirty!!!!
    LOL!!!
  4. #4 Re: 04+ Rack and Pinion replacement
    Rockford, IL
    sory for no pics, my parents didnt want my dirty hands even coming close to their cameras..lol wonder why....
  5. #5 Re: 04+ Rack and Pinion replacement
    Edwardsville, Pa
    This may be a stupid question. What is the benifit of the newer 04+ steering rack. Does it have a better ratio. If so would it make a huge difference in the car.
  6. #6 Re: 04+ Rack and Pinion replacement
    Oklahoma
    Thats a good question. Is there a difference in the 04+ from the 97-03 that would make it an upgrade?
  7. #7 Re: 04+ Rack and Pinion replacement
    Rockford, IL
    the 04+ have electronic magna steer. This was just a repair as FastKatt's original rack failed.
    this was not an upgrade.....
  8. #8 Re: 04+ Rack and Pinion replacement
    SE Level Member Sinister Drag Designs's Avatar
    just ditch the stock rack and get an Omni manual unit.
    very little up keep
  9. #9 Re: 04+ Rack and Pinion replacement
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Quote Originally Posted by Sinister Drag Designs View Post
    very little up keep
    What do you mean by this?
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  10. #10 Re: 04+ Rack and Pinion replacement [*]
    Aug 2008
    KCMO
    how can you tell if your rack and pinion goes out?
  11. #11 Re: 04+ Rack and Pinion replacement [*]
    Feb 2008
    Rkrd, IL
    On mine, it became almost impossible to turn to the left, but turning right was normal
    I assume it's not the same all the time...
    My guess, some people it would just be impossible to turn at all...
  12. #12 Re: 04+ Rack and Pinion replacement [*]
    Memphis
    Is this the same removal as for the 1998 Grand Prix?
  13. #13 Re: 04+ Rack and Pinion replacement [*]
    MT
    Should I be concerned if my wheel won't "lock"? With the key in the lock position I can still turn the wheel side to side all the way.
    And good to know about the magna-steer. I had an error pop up on the DIC that said service steering and when it didn't work it was one hell of a difference. Next time I started the car the error was gone and it's been good from then on.
  14. #14 Re: 04+ Rack and Pinion replacement [*]
    Jan 2012
    MN
    link no longer works
  15. #15 Re: 04+ Rack and Pinion replacement [*]
    Nov 2010
    Michigan
    Yeah, anyone have an updated link for this rack replacement write-up? I see this project being necessary for my 2005 in the very near future.
  16. #16 Re: 04+ Rack and Pinion replacement [*]
    I don't have a write up...but check me out.
    Jack and support car (usually at factory jacking locations right behind front wheels.
    Remove both wheels
    Remove the nuts holding the tie rods to knuckles and free tie rods from knuckles
    Ensure steering wheel is straight and can not turn
    Lift rubber boot on top of rack and unbolt the 11mm holding the telescoping shaft to the rack. Wiggle it free
    Lower rear of subframe about 2-3 inches and support at that height
    Disconnect the two ps pump lines at the rack
    Remove two bolts holding rack to subframe
    Slide rack out the wheel well and reverse for installation.
    Once completed, start car and fill ps res.
    Turn wheel a few times in both directions an allow system to bleed air out.
    Repeat with fluid/turning and sitting until system is at the correct level and not making noise.
  17. #17 Re: 04+ Rack and Pinion replacement [*]
    Nov 2010
    Michigan
    Thanks Bill! I have done the complete steering system on my lifted GMC Sonoma ZR-2, so I feel a little weird being intimidated by the tight quarters that I have to work in for getting at this rack (and probably the power steering pump while I'm at it).
  18. #18 Re: 04+ Rack and Pinion replacement [*]
    When you lower the back of the cradle 2-3 inches, it won't seem so tight or cramped. BTW, if you are considering change the sway bar or the center bushings, it's a perfect time to get at the bolts for the center bushings.
  19. #19 Re: 04+ Rack and Pinion replacement [*]
    Silverdale, WA
    Thanks for the tip on lowering the subframe. . .I think that will help me out. . .and the part about the 11mm bolt inside the rubber boot, although moving that boot around is a PITA!!!
  20. #20 Re: 04+ Rack and Pinion replacement [*]
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Thanks Bill for the R&R on the Rack, I have not found anything on the forum about replacing the seals. Has anyone tried it? I see seals listed as a part in parts store. My GM buddy said when he was in school they did not go into the rack, just replaced it. Is this kind of like rebuilding master cylinders today, vs back when I did it in the 80's? Anyone any thoughts?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Really Nice Rack!
    By FastKatt in forum Off Topic Discussion
    Last Post: 04-05-2008, 04:22 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
