Thread: need advice with installing a throttle body spacer
Results 1 to 18 of 18
  1. #1 need advice with installing a throttle body spacer
    Nov 2009
    Iowa
    i have an 01 gt
    i am trying to install a Airaid throttle body spacer. i got the the throttle body off, but when i was taking out the studs that hold the throttle body, the one on the top sheered on the end, so i cant get the stud out. The only thing that i can think to do is just use a vice grip to get it out. any better ideas?
  2. #2 Re: need advice with installing a throttle body spacer
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    just use the vice grips you wont use the studs anymore anyways.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  3. #3 Re: need advice with installing a throttle body spacer
    Banned
    Wichita Falls, Texas
    Yeah, great idea. Throw the spacer in the garbage unless your drilling and tapping it for a shark nozzle.
  4. #4 Re: need advice with installing a throttle body spacer
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    x2^^ Your better off getting a hv3 insert instead
  5. #5 Re: need advice with installing a throttle body spacer
    Kansas
    Let the guy do what he wants
    SOLD 1999 GT Silvermist TS
  6. #6 Re: need advice with installing a throttle body spacer
    Banned
    Quote Originally Posted by Gafford44 View Post
    Shut up noob. Not only is it a useless mod, it's also a unnecessary danger since it blocks the coolant flow to the TB.
  7. #7 Re: need advice with installing a throttle body spacer
    Kansas
    Quote Originally Posted by Street Wolf View Post
    Shut up noob. Not only is it a useless mod, it's also a unnecessary danger.
    Ok but all he asked was for help installing it..
  8. #8 Re: need advice with installing a throttle body spacer
    Banned
    Which he got help with. However he also brought up the subject of the TB spacer in general, and should be made aware of how useless it is and the fact that it has also caused problems on multiple reputable people's vehicles during the winter time who live in an area that gets cold enough for temperature to effect it.
  9. #9 Re: need advice with installing a throttle body spacer
    Kansas
    Which he got help with. However he also brought up the subject of the TB spacer in general, and should be made aware of how useless it is and the fact that it has also caused problems on multiple reputable people's vehicles during the winter time who live close enough to temperature to effect it.
    Okay.
  10. #10 Re: need advice with installing a throttle body spacer
    Isnt the only purpose so the valve doesnt stick? If your TB is looked after then it really shouldnt be an issue.
  11. #11 Re: need advice with installing a throttle body spacer
    Feb 2008
    IIRC, doesn't the Airaid spacer have coolant ports?
  12. #12 Re: need advice with installing a throttle body spacer
    Jan 1970
    Maquoketa, Iowa
    For everyone elses info... If your going to block off the coolant passages to the tb, it helps to open up the coolant passage in the LIM located under the EGR/LIM. You can do this by taking off the plate and drilling or notching out another 1/4" to the passageway. This is to make up for the coolant that was supposed to be going to the rear head but is now blocked at the tb/lim.
  13. #13 Re: need advice with installing a throttle body spacer
    Nov 2009
    Iowa
    why is the temp. of the T.B. a big deal?
  14. #14 Re: need advice with installing a throttle body spacer
    Jul 2008
    Livonia MI.
    I think its for condensation/frost buildup wile driving? keeping the tb warm,
    sticking throttle blade? It could also be emissions related too
  1. throttle body spacer
    By danross in forum General Tech Discussion
    Last Post: 02-19-2009, 06:40 PM
  2. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  3. throttle body spacer
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:45 PM
  4. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
