Thread: eliminate daytime running lights (headlights) 04+ grand prix
Results 1 to 17 of 17
  1. #1 eliminate daytime running lights (headlights) 04+ grand prix
    GT Level Member BLKGP's Avatar
    South Bend, Indiana
    See the original thread here
    http://www.grandprixforums.net/f71/h...hts-22162.html
    I did this in my 2008 grand prix so i could run HIDs, it may work in earlier models as well. This is for grand prix's that have headlights as daytime running lights.
    I ASSUME NO RESPONSIBILITY IF YOU MESS THINGS UP.
    DO THIS AT YOUR OWN RISK
    This will void your warranty!!
    PLEASE READ CAREFULLY!!
    first thing you need to do is remove the panel on the side of the dash, the BCM is located here
    once you have that panel off, remove the small kick panel underneath the dash, it's held in by 3 push pins, twist the foot well light to remove it. once you have that off, remove the radio bezel
    remove the 3 screws that hold the dash panel in and pull the panel straight out.. now you will see 3 screws that hold the BCM in, remove them
    unclip the harness from the left side of the BCM, it may be zip tied, if so cut the tie.. THIS HARNESS IS NOT USED.. once that harness is out you can pull the BCM out from underneath.. unclip both harnesses from the bottom.
    carefully cut away at the electrical tape and expose the wiring on both bottom harnesses..
    locate pin #7 (WHITE WIRE) on the smaller harness. see diagrams below
    Use a wiretap to tap into this wire and connect it to pin 85 on your relay
    Now locate pin #9 on the bigger harness (PINK/WHITE WIRE) see diagram below
    CUT this wire and crimp on female connectors to both ends.
    ignore the wiretap on the white wire DO NOT use the white wire.
    Connect the wire from the BCM harness side to pin 87 on the relay.
    Connect the wire coming from the firewall to pin 30 on the relay.
    Now you need to find a constant 12 volt source, i used the radio harness, but any constant 12 volt source will work.. Run a wire from pin 86 on the relay to the 12 volt source.. and thats it, you're done. no more DRLs
    final product, make sure your connections are tight and tape everything back up
    pinout diagrams
  2. #2 Re: eliminate daytime running lights (headlights) 04+ grand prix
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    bump, since this is a hot topic right now
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  3. #3 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Willoughby, Ohio
    good info, nice writeup
  4. #4 Re: eliminate daytime running lights (headlights) 04+ grand prix
    SE Level Member ChicagoGXP's Avatar
    Chicago
    This should be stickied! Awesomeness.
    I assume that the automatic headlights still work correct?
  5. #5 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Chicago
    Also, could you explain how this works please?
  6. #6 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Orlando, FL
    I was wondering if you could just pull out the plug that goes into the heatsink behind driverside dash. Would that disable the daytime running lights and keep the autolighting system working without not problems coming up in the DIC.
  7. #7 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Willoughby, Ohio
    ^^^for the 97-03s yes
  8. #8 Re: eliminate daytime running lights (headlights) 04+ grand prix
    May 2011
    wisconsin
    So had anyone done this yet to prove that it works? I'm guessing if this works out would be for 06-08. I myself have a 07 prix gt and I want my hids in so I ned my drl off. When someone else does this please post and let us all know if out works and take a picture of proof please. Also for the guy who did this post you should make a youtube video and how to do this, you would get bazillions of views in one day .
  9. #9 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Bunnell, FL
    ^^^ more like 5 posts in your thread
    I'm a Sex Offender
  10. #10 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Oct 2012
    Luverne, MN
    What size/type of relay is that? And where can I get one of those and a wire tap?
    Thanks
  11. #11 Re: eliminate daytime running lights (headlights) 04+ grand prix
    South Bend, Indiana
    your local auto parts store should have everything you need
  12. #12 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Enfield, CT
    Ik this thread is old but this write-up is something I'm looking forward to doing and I just wanted to know If anyone has done this recently.
  13. #13 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Oct 2014
    Fort Gratiot mi
    Has any one done this ?
  14. #14 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Enfield, CT
    Quote Originally Posted by Scratcher View Post
    Yes. Works flawlessly.
  15. #15 eliminate daytime running lights (headlights) 04+ grand prix
    Aug 2013
    McDonald PA
    Is this the only way of doing this?
  16. #16 Re: eliminate daytime running lights (headlights) 04+ grand prix
    Enfield, CT
    There is another way to do this but I choose this way and I prefer this way too. Somewhere on here there is a thread on how to do it another way. If you need help with something LMK
  17. #17 Re: eliminate daytime running lights (headlights) 04+ grand prix
    May 2014
    Detroilet
    I know this is an old topic but is there any way to re upload the pics that are missing from the original post?
  1. HIDs and DRL.. eliminate daytime running lights!
    By BLKGP in forum General Tech Discussion
    Last Post: 11-11-2012, 10:57 AM
  2. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  3. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
  4. How to disable daytime running lights.
    By ChvyTrcksFrdScks in forum How To Write-Ups/Tech Tips
    Last Post: 05-09-2009, 04:15 PM
  5. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
