Thread: Make A 4" Fenderwell Intake (FWI)[*]
Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 121 to 140 of 199
  1. #121 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member Feather Head's Avatar
    Wausau
    99 GT - SD Headders, EGR delete, Custom Tune, HV3
    70's Sears-Fully built OHV Briggs Single
  2. #122 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GT Level Member Robroy04gtpcompG's Avatar
    ca
    Let's see your setups then. Give me something to go off of, as this is the bull**** I got off of this forum!
  3. #123 Re: Make A 4" Fenderwell Intake (FWI)[*]
    in a house
    Quote Originally Posted by Robroy04gtpcompG View Post
    Show me one post where a knowledgable member of this forum suggested using 3" tubing. Don't blame this forum because you put NO research into this and then posted pics of it like it was the cats ass. As far as pics, their is a million threads on intakes. SEARCH
  4. #124 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Wausau
    Dude read what i posted above. ZZP did a flow bench test with different lengths of pipes, sizes and bends.
  5. #125 Re: Make A 4" Fenderwell Intake (FWI)[*]
    ca
    Thank you feather head. I appreciate the info. I am going to try a short ram setup now and see how it works. I will post pics because I need the input from you guys, whether good or negative. It's all about making my Comp G haul @$$!
    Ok guys, so there are no bends now in my intake! I am going to go to my bro's shop and see about custom fabricating a heat shield for the filter that doesn't look ghetto. Obviously after reading your input from the last setup, I know I ****ed up BIG time! So, how is this?
  6. #126 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Wausau
    Much better
  7. #127 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Heat shield won't help much.
    header wrap or stainless steel headers will though.
  8. #128 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Can somebody tell me what the 3" to 4" Coupler is suppost to do?? My TB is 3 3/4" ??
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  9. #129 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    how long does making and installing the FWI typically take?
    keep in mind i have a '98 so my coolant container needs to be moved. do i just move it or do i need to but a '99+ container (idk if there is a difference between the two) and how do i mount it just drill it into the tower or something else?
    if you cant tell im kinda going into this with a blindfold on thanks for any help though
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  10. #130 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    you gotta get a bottle from a 99+, you will see when you get it, how it works (just hit up a junkyard)
  11. #131 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Wausau, WI
    the 99 and up are a different shape and get mounted on the inside of the strut tower brace on the passenger side. They are shaped very differently. It is not hard to do.
  12. #132 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    nobody wants to answer my question??
  13. #133 Re: Make A 4" Fenderwell Intake (FWI)[*]
    ca
    my stock throttlebody took a 3"coupling on it, so i think it is to adapt to 4" pipe for your intake. i got some **** from some of the guys, and ended up doing the short ram intake. basic, and effective.
  14. #134 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    thanks bud, I read all the threads, But like I said, My tb intake is not 3", it is 3 3/4, so I would be better off with a 4" and a good clamp.
  15. #135 Re: Make A 4" Fenderwell Intake (FWI)[*]
    ca
    that should work. i am going to get a larger MAF and throttle body soon.
  16. #136 Re: Make A 4" Fenderwell Intake (FWI)[*]
    No, a 3 to 4 will fit on it just fine. a 4 would probably be way too big.
  17. #137 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    I'm not sure what type of rubber yours is made of but the 3 to 4 that I found will not stretch 3/4 of an inch. I found a rubber 3 1/2" - 45* elbow that I think is going to work great, it is from a Parts store for Semi's, I am going to run that, with 3 1/2" Alumimum Turbo tubing, if he can get me a 3 1/2" to 4" for the filter
  18. #138 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Heat.
    it solves everything
  19. #139 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member daveydavido's Avatar
    Feb 2010
    detroit
    The spectre filter i bought from autozone had rubber adapters in different diameters, that fit into the filter to make it from 3"-4". Thats 4in diameter aluminum sheet FYI.
    So i bought my 90 degree elbow which was 4in in/out. Cut it, then i put one of the adapters in the end and attached it to my tb. So i didnt need the 3 to 4 coupler, the adapter dealie took my 4 and made it into a 3.25 whcih went nicely onto the tb. looks like this:
    and today i made a heatshield that looks like this
    1997 GTP 88k - custom intake and heatshield(DIY), tinted tails, 10000k Hids, black housed headlights
    http://www.grandprixforums.net/f73/how-make-heat-shield-your-intake-29052.html#post339264
  20. #140 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member dbrincefield's Avatar
    Feb 2010
    Dayton
    will this same set up work on an 03 Monte Carlo SS?!?
  1. Make a difference section
    By LowlyfeGTP in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 03:15 PM
