Re: Make A 4" Fenderwell Intake (FWI)[*]
Is there any real difference between this:
http://i250.photobucket.com/albums/g...0808091914.jpg
and the FWI
Yes that is a short ram pulling hot air from the engine bay. The fwi puts the air filter in the fender pulling in cold air. fwi> short ram unless u are using alky/intercooled.
Would i need and clamps or brackets or anything how much did this cost you
my question is for vailskiier. I have an 08 with the MAF like yours. How did you go about getting a leeve to fit on the air box side of the MAF. Mine bolts into the air box.. is that how yours is too?
I have an 07 and the MAF bolts on the airbox too, it looks like he used the coupler from the original airbox.
2 Attachment(s)
Heres mine on an 07, needs a bit of cleaning up, but works great.
mike171562
thats a 3in pipe... not 4 inch... stock is basically a 3in as well
yes but why would you need a 4 inch pipe when the throttle body its going into is only 3 inches. and the MAF is only 3 inches. Doesnt make any sense
Thats what I was thinking, if there is a 3 inch bottleneck at the MAF and the throttle body, I did not see that it would make much difference.
Because some people actually have a set-up that allows 4" all the way through into the blower casing.
tlane3546
also my MAF is directly on my TB......so for me, the four inches allows for as much possible flow through the bends, angles and the air capacity that the IAT gauge sits........so you are getting a full three inches worth(or whatever max capacity is) into the TB......otherwise these things would not allow a true three inch pipes worth of flow into the TB.
I don't know if it's just me.. but I can't find a 4" Flexable Elbow anywhere, I tried Home Depot and Lowes.
KawaFord
Yeah, your going to have one hell of a time finding it too.
I can probably get you one, or you can order one off line though.
I'm just going to hold off on FWI until I have enough $ for a wiz intake.
KawaFord
:th_scratchhead:
Run that by me one more time. That intake is uber fail. Get the TDC instead.
KawaFord
You look at the TDC FWI yet? better look, and functionality for a better price in my opinion........it is your car though...
Liquifire
Why buy TDC, when you can make one for a fraction of the cost?
KawaFord
Exactly...so why in the f**k are you going to buy a Wizaired...IDK you just contradicted yourself.
oh I'll be doing the FWI maybe next week sometime after pay day.
i did it and it works awesome.
