I have read on an other site that you can drill a 3-4 inch hole in your airbox and run tubing in the fender. Has anyone you no tried this? I think it sounds like a pretty good idea but value the opinion of others.
sound like a good idea....but not worth it I had that setup for a while but the fenderwell was alot better... trust me go fenderwell
Did it last night to my 04 gtp....worked great....ran all 3 inch parts though so i didnt have to cut....did it all through the foglight also....easy cheap....:th_thumb-up:
thanks street wolf, awesome write up...mine is a little different cuz its an 07, but here's how mine is. i'm not done, cuz i want to paint the pvc with header paint maybe, and i want to close off the fw a little better
http://www.grandprixforums.net/membe...n-progress.jpg
heres mine works great :)
http://img19.imageshack.us/img19/9905/fwi.jpg
Can anyone post any results on the effects this had on gas mileage?
rmmm....I was going to just get mandrel bent pipe.....but this is cheaper!! woohoo!! Im getting a FWI intake tonight woohooo :th_dancingbanana::th_dancingbanana:
personally, i noticed a 1mpg increase...but i've heard that a fwi is supposed to take it down 1 or 2...idk
Doesn't painting PVC piping actually make it weaker? I'm sure if you use the header paint to keep heat out it does its job, but when I built my potato launcher it was highly recommended that we don't paint PVC due to the weakening of its structure.
I'm guessing it probably wouldn't matter if its an intake rather that's not dealing with too high of PSI, instead of piping with high pressures of water or in my case combustion.
Is there any way to do this with the 4" without removing/cutting the brace in the fender? If not, whatd you use to cut it? I've had a hell of a time trying to get the back bolt to take it out and just cant seem to get anything that fits back there
on my setup , i did not cut the inner fender brace cause i used a conical air filter which is about 4 inches high part number 8162 from Spectre , they sell it at Autozone and it fits just perfect . instead of the 4 inch tubing i used 3 inch . i know that 4 inch is bigger and has a better flow , but a 3 inch is smaller and consecuently faster air flow , my FWI intake roars very fukng loud :th_peaceout:
http://i40.photobucket.com/albums/e2...I/DSC02900.jpg
http://i40.photobucket.com/albums/e2...I/DSC02910.jpg
http://i40.photobucket.com/albums/e2...I/DSC02906.jpg
http://i40.photobucket.com/albums/e2...I/DSC02902.jpg
http://i40.photobucket.com/albums/e2...I/DSC02912.jpg
Thanks for the post! Only problem is i checked this about 5 minutes too late, lol. Just got it all fitted in and finished! So im not sure how all you people with 9" cones have it fitted in as you did, but from your pictures i could not get mine in anything like yours! Luckily with a lot of cussing and trying to make everything fit in, Ive completed it, though it appears different from the pictures and i had to use the other half of the 90* angle down in the fender well.
For a note to those who dont want to cut the brace, you dont have to. I just unscrewed the one inside bolt(the one closer to the engine, not the fender one) and pretty much just bent/forced it it out towards the fender. As another note, i tried removing it and im not sure if there is an easier way, but that back bolt was a b**** to get to. Then after i finally managed to get it off, i noticed the little triangular clip thing and couldnt figure how to remove that so gave up on that idea. I'm sure it's easy to remove just didnt feel like searching.
Now that i've typed a essay here.... Good write up streetwolf, and good luck to those who try this in the future. Trying to use a smaller cone might be easier, though it doesnt look as bad ass, might save your breath on some cursing:p
nothin gets things done quite like a few beers and a whole lotta cussin ;)
quick question for vailskier3 what kind of filter did u use im trying to do this on my 05 and i got a 6 inch cone and it seems way to big to fit and im not sure if i should find a different one or if i could mod the fender frame to fit i guess and how long is your pvc piece? thanks
Hey i love this mod! I am going to try it out this weekend. A couple questions though;
Where does everyone mount their PCMs?
And also would i need to relocate my coolant bottle? (98 Grand Prix)
Thanks!
you didnt see my pcm right next to my coolant bottle , did you ? its right there in the pics. on the bottom of my pcm i used the sponges that came right out of the airbox to absorb impact or vibration and took a screw off my pcm cover and drilled it to my chassis again with the sponge in between pcm and chassis ..
