Thread: 60 V6 Engine Water Pump Removal And Install [*]
Results 1 to 5 of 5
19SE92 60 V6 Engine Water Pump... 03-02-2008, 11:26 PM
BackInBlack Re: 60 V6 Engine Water Pump... 03-03-2008, 12:14 AM
UR LOSN Re: 60 V6 Engine Water Pump... 03-03-2008, 12:22 AM
19SE92 Re: 60 V6 Engine Water Pump... 03-03-2008, 12:27 AM
BackInBlack Re: 60 V6 Engine Water Pump... 03-09-2008, 09:15 AM
  1. #1 60 V6 Engine Water Pump Removal And Install [*]
    Banned
    New Port Richey Florida
    This writeup on Water Pump Replacement on 3.1L Engines has been added to the How To section and can be found HERE.
    Last edited by SyntheticShield; 03-02-2008 at 11:51 PM. Reason: Edited for easier reading
  2. #2 Re: 60 V6 Engine Water Pump Removal And Install
    GT Level Member BackInBlack's Avatar
    Vermont
    Step 0.5) Disconnect negative battery terminal.
    The GPs are long gone...
  3. #3 Re: 60 V6 Engine Water Pump Removal And Install
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^^for that you would either have to have small hands, or take the washer fluid resivoir/airbox out to get to it.....
    i could be mistaken...been a few years since I've had my 95.
  4. #4 Re: 60 V6 Engine Water Pump Removal And Install
    Banned
    Your right the battery sits under the washer bottle
  5. #5 Re: 60 V6 Engine Water Pump Removal And Install
    Vermont
    ...Which only takes about 30 seconds to remove and set aside...
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  3. Easy Dent Removal
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 04-04-2008, 05:17 PM
  4. Water Logged Passenger Floor
    By Toofastgs in forum Buick Regal
    Last Post: 01-22-2008, 01:59 PM
